DTMF to remote CUE
I have two sites with one CME installation each, and an integrated CUE on the second site (site B).
If i´m doing a call from site A (7940 sccp phone) to the CUE via the CME of site B, i can´t get the DTMF tones through.
If i configure a dial peer on CME A which points directly to the address of the CUE in site B, the DTMF tones
are working fine.
Not-working configuration (Dial Peer points to CME on site B):
dial-peer voice 1401 voip
description To CME in Site B
destination-pattern [5][8][0-4][0-9]
session protocol sipv2
session target ipv4:10.38.0.2
codec g711ulaw
no vad
Working configuration (Dial Peer points directly to CUE on site B):
description To CUE in Site B
destination-pattern 5848
session target ipv4:10.38.0.3
codec g711ulaw
no vad
CME-Configuration of Site B:
dial-peer voice 2 voip
description **Incoming Dial Peer for calls from Site A**
incoming called-number 58..
codec g711ulaw
dial-peer voice 9998 voip
description CUE PromptMgmt
dtmf-relay sip-notify
codec g711ulaw
no vad
Any hints are much appreciated!
Heinz
Hall of Fame Super Silver
DTMF to remote CUE
Add dtmf-relay to dial-peers on site A.
HTH,
Chris
DTMF to remote CUE
Hi Heinz,
I think it is related to dtmf negotiation, you need to configure transcoder on site B to do the dtmf negotiation.
with your non working config check debug ccsip media to see what is the negotiated dtmf.
Anas
please rate all the helpful posts
Re: DTMF to remote CUE
Seems to be g711 end to end, so normally there is no transcoding involved here.
use the following command on your dial-peer
dtmf-relay rtp-nte
this will allow the dtmf signal to travel on top of rtp
DTMF to remote CUE
i already tried all variants of dtmf-relays on the outgoing dial-peers of site A, but none of them worked.
It seems to be that the DTMF codes are removed from the stream on the CME router B when it forwards
the call to the CUE.
Any more ideas?
Heinz
Bronze
Hi Heinz,
As suggested by other friend, pls share the logs captured with "debug ccsip media" command on CME at site B while making test calls to CUE.
And, have you got any logs on CmE at site A confirming the issue with DTMF only?
Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
DTMF to remote CUE
below is the output of a "debug ccsip media" while connecting to the CUE to from Site A to Site B.
No matter what kind of DTMF relay I use on the Dial Peer of Site A, i can´t get the tones trough.
Again: If i´m pointing the dial-peer of Site A directly to the remote CUE, it always works.
Heinz
002944: Jul  7 13:47:34.277 CEST: //-1/D79FCF7586DA/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
002945: Jul  7 13:47:34.277 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.38.0.2
002946: Jul  7 13:47:34.277 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 fo
r codec g711ulaw
002947: Jul  7 13:47:34.277 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711ulaw, bytes :160
        Preferred  DTMF relay  : inband-voice
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
002948: Jul  7 13:47:34.277 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.38.0.2
002949: Jul  7 13:47:34.277 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIDisplayStreamInfo:
          Stream type            : voice-only
          Media line             : 1
          State                  : STREAM_ADDING (2)
          Stream address type    : 1
          Callid                 : 157399
          Peer Callid            : -1
          RTP/SRTP Negotiated     : 8
          Negotiated Codec       : g711ulaw, bytes :160
          Nego. Codec payload    : 0 (tx), 0 (rx)
          Negotiated DTMF relay  : inband-voice
          Negotiated NTE payload : 0 (tx), 0 (rx)
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : [10.38.0.2]:0
          Media Dest Addr/Port   : [10.38.8.2]:16940
002950: Jul  7 13:47:34.277 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Media line             : 1
          Callid                 : 157399
002951: Jul  7 13:47:34.277 CEST: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 19160 for stream 1
002952: Jul  7 13:47:34.277 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIDisplayStreamInfo:
          Media line             : 1
          Callid                 : 157399
          Peer Callid            : -1
          Media Srce Addr/Port   : [10.38.0.2]:19160
002953: Jul  7 13:47:34.281 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
002954: Jul  7 13:47:34.281 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.38.0.2
002955: Jul  7 13:47:34.281 CEST: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 19126 for stream 1
002956: Jul  7 13:47:34.281 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_IDLE
002957: Jul  7 13:47:34.281 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIProcessRtpSessions: No active streams.
002958: Jul  7 13:47:34.285 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
002959: Jul  7 13:47:34.285 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 157400) to the VOIP RTP library
002960: Jul  7 13:47:34.285 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.38.0.2
002961: Jul  7 13:47:34.285 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
002962: Jul  7 13:47:34.285 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.38.0.2, lport = 19126, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
        src_callid = 157400, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
        media_ip_addr =  - , vrf tableid = 0 media_addr_type = 1        negotiated_bandwidth (kbps) = 0
002963: Jul  7 13:47:34.285 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
002964: Jul  7 13:47:34.285 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPICreateRtpSession: stun is disabled
002965: Jul  7 13:47:34.285 CEST: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: Voice quality monitoring is not enabled for this RTP session due to sdp p
assthru enabled
002966: Jul  7 13:47:34.285 CEST: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=157400
002967: Jul  7 13:47:34.321 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.38.0.2
002968: Jul  7 13:47:34.321 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
002969: Jul  7 13:47:34.321 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred  DTMF relay  : sip-notify
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
002970: Jul  7 13:47:34.321 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.38.0.2
002971: Jul  7 13:47:34.325 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIDisplayStreamInfo:
          Media line             : 1
          Callid                 : 157400
          Peer Callid            : -1
          Negotiated DTMF relay  : sip-notify
          Media Srce Addr/Port   : [10.38.0.2]:19126
          Media Dest Addr/Port   : [10.38.0.3]:20898
002972: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
002973: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
002974: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
002975: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
002976: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
002977: Jul  7 13:47:34.325 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Media line             : 1
          Callid                 : 157400
002978: Jul  7 13:47:34.325 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:35CCDBD8
002979: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
002980: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice-only (callid 157399) to the VOIP RTP library
002981: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.38.0.2
002982: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
002983: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.38.0.2, lport = 19160, raddr = 10.38.8.2, rport=16940, do_rtcp=TRUE
        src_callid = 157399, dest_callid = 157400, stream type = voice-only, stream direction = SENDRECV
        media_ip_addr = 10.38.8.2, vrf tableid = 0 media_addr_type = 1  negotiated_bandwidth (kbps) = 0
002984: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
002985: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPICreateRtpSession: stun is disabled
002986: Jul  7 13:47:34.325 CEST: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: Voice quality monitoring is not enabled for this RTP session due to sdp p
assthru enabled
002987: Jul  7 13:47:34.325 CEST: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=157399
002988: Jul  7 13:47:34.325 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIGetNewLocalMediaDirection:
        New Remote Media Direction = SENDRECV
        Present Local Media Direction = SENDRECV
        New Local Media Direction = SENDRECV
        retVal = 0
002989: Jul  7 13:47:34.325 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
002990: Jul  7 13:47:34.325 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice-only (callid 157400) to the VOIP RTP library
002991: Jul  7 13:47:34.325 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.38.0.2
002992: Jul  7 13:47:34.325 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
002993: Jul  7 13:47:34.325 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.38.0.2, lport = 19126, raddr = 10.38.0.3, rport=20898, do_rtcp=TRUE
        src_callid = 157400, dest_callid = 157399, stream type = voice-only, stream direction = SENDRECV
        media_ip_addr = 10.38.0.3, vrf tableid = 0 media_addr_type = 1  negotiated_bandwidth (kbps) = 0
002994: Jul  7 13:47:34.325 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
002995: Jul  7 13:47:34.325 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:35CCDBD8
002996: Jul  7 13:47:34.325 CEST: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=157400
002997: Jul  7 13:47:34.325 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 0
002998: Jul  7 13:47:45.077 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:367D9708
002999: Jul  7 13:47:45.077 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:35CCDBD8
003000: Jul  7 13:47:45.081 CEST: //157399/D79FCF7586DA/SIP/Media/sipSPIHandleDestroyRtpSession: stream:367D9708
003001: Jul  7 13:47:45.081 CEST: //157400/D79FCF7586DA/SIP/Media/sipSPIHandleDestroyRtpSession: stream:35CCDBD8
Hi Heinz,
On the inbound dial peer of CME B can you please configure session protocol sipv2 and try the dtmf?
Regards, Avinash
Also I would say add the dtmf relay on the inbound dialpeer.
Remember that this dial peer is forwarding to your cue module.
I hope it helps.
520
