dtmf tones failing (SIP-->H323)
Hi.
I have a DDI(SIP) mapped onto an IVR i am using h323 protocol between us and the customer. When i run the debugs h245 asn1 and voip rtp session named-event i can see that the SIP provider is forwarding us the right dtmf (rtp-nte) but when we send them out via h245 alphanumeric not all dtmf tones are transmitted.
This is an intermittent issue which has been failing a lot lately. Is there anyway to fix this can we use a reliable mode for dtmf transmissions?
I am attaching the logs for your reference.
The digits pressed on this call was
Choose Language ( Pressed 1) -----> Transmitted
Dial-Extension (1011921) -----------> Failed ( not all tones transmitted).
Hassan
  • IP Telephony
have you configured the dtmf-relay rtp-nte digit-drop command on the incoming SIP dial-peer?
//Suresh Please rate all the useful posts.
I didnt have the command in but tried with this command and the same issue...
VIP Super Bronze
Please share your config with us...current running config
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Attaching the incoming and outgoing dial-peer would that be ok?
INCOMING
dial-peer voice 76 voip
translation-profile incoming SIP-INBOUND
media flow-around
signaling update from gtd  calling
session protocol sipv2
session target sip-server
incoming called-number 4486105695xxxx
voice-class codec 1
dtmf-interworking rtp-nte
no vad
OUTGOING
dial-peer voice 861572 voip
destination-pattern 86105695xxxx
session target ipv4:2.3.xxx.xxx
dtmf-relay h245-alphanumeric
no vad
VIP Super Bronze
I am not sure if this is okay..it all depends on if these are the dial-peers matched for the calls...You need to use debug voip ccapi inout to check if these are the dial-peers matched...If they are then please do the ff:
no dtmf-interworking rtp-nte
Remove that command and test again...
May I ask why you are using media-flow around?
Can you also post the full output of
debug voip rtp named session-event
debug h225 asn1
debug h245 asn1
In addition to the above, I would request you to kindly share the complete call-flow as in the following example:
PSTN--SIP TRUNK--CUBE---H323--CUCM--IP PHONE
Also to narrow down the issue I would request you to collect sniffers from the egress and ingress interfaces of the CUBE and check if the DTMF tones are passing through the CUBE properly.
If the end device is a CUCM then while making the test call also collect the detailed SDI/SDL traces for the call.
Re: dtmf tones failing (SIP-->H323)
Hi Guys,
The flow is
PSTN----SIP-TRUNK------CUBE-----H323------CUCM-----IVR
I have tried removing the configuration but it did not help. Is there anyway to send reliable DTMF?
I am attaching the logs thank you so much for the help.
VIP Super Bronze
Looking at the logs, the DTMF packets appear not to be properly formatted..Each digit pressed should generate 7 packets..lets look at the digit 9 pressed here and used that to explain how this should work..I will be looking at the receive direction for explanation purposes
Dec 16 12:35:28.755 GMT:          s=DSP d=VoIP payload 0x65 ssrc 0x44F5236F sequence 0xB898 timestamp 0x32A0
Dec 16 12:35:28.755 GMT:          Pt:101    Evt:9       Pkt:0A 06 40  >>
Dec 16 12:35:28.775 GMT:          s=VoIP d=DSP payload 0x65 ssrc 0x44F5236F sequence 0xB899 timestamp 0x32A0
Dec 16 12:35:28.775 GMT:  << Pt:101    Evt:9       Pkt:0A 06 E0
Dec 16 12:35:28.775 GMT:          s=DSP d=VoIP payload 0x65 ssrc 0x44F5236F sequence 0xB899 timestamp 0x32A0
Dec 16 12:35:28.775 GMT:          Pt:101    Evt:9       Pkt:0A 06 E0  >>
Dec 16 12:35:28.795 GMT:          s=VoIP d=DSP payload 0x65 ssrc 0x44F5236F sequence 0xB89A timestamp 0x32A0
Dec 16 12:35:28.795 GMT:  << Pt:101    Evt:9       Pkt:0A 07 80
Dec 16 12:35:28.795 GMT:          s=DSP d=VoIP payload 0x65 ssrc 0x44F5236F sequence 0xB89A timestamp 0x32A0
Dec 16 12:35:28.795 GMT:          Pt:101    Evt:9       Pkt:0A 07 80  >>
Dec 16 12:35:28.815 GMT:          s=VoIP d=DSP payload 0x65 ssrc 0x44F5236F sequence 0xB89B timestamp 0x32A0
Dec 16 12:35:28.815 GMT:  << Pt:101    Evt:9       Pkt:0A 08 20
Dec 16 12:35:28.815 GMT:          s=DSP d=VoIP payload 0x65 ssrc 0x44F5236F sequence 0xB89B timestamp 0x32A0
Dec 16 12:35:28.815 GMT:          Pt:101    Evt:9       Pkt:0A 08 20  >>
Dec 16 12:35:28.835 GMT:          s=VoIP d=DSP payload 0x65 ssrc 0x44F5236F sequence 0xB89C timestamp 0x32A0
Dec 16 12:35:28.835 GMT:  << Pt:101    Evt:9       Pkt:0A 08 C0
Dec 16 12:35:28.835 GMT:          s=DSP d=VoIP payload 0x65 ssrc 0x44F5236F sequence 0xB89C timestamp 0x32A0
Dec 16 12:35:28.835 GMT:          Pt:101    Evt:9       Pkt:0A 08 C0  >>
Dec 16 12:35:28.855 GMT:          s=VoIP d=DSP payload 0x65 ssrc 0x44F5236F sequence 0xB89D timestamp 0x32A0
Dec 16 12:35:28.855 GMT:  << Pt:101    Evt:9       Pkt:8A 09 60
Dec 16 12:35:28.855 GMT:          s=DSP d=VoIP payload 0x65 ssrc 0x44F5236F sequence 0xB89D timestamp 0x32A0
Dec 16 12:35:28.855 GMT:          Pt:101    Evt:9       Pkt:8A 09 60  >>
Dec 16 12:35:28.855 GMT:          s=VoIP d=DSP payload 0x65 ssrc 0x44F5236F sequence 0xB89E timestamp 0x32A0
Dec 16 12:35:28.855 GMT:          s=DSP d=VoIP payload 0x65 ssrc 0x44F5236F sequence 0xB89E timestamp 0x32A0
Dec 16 12:35:28.855 GMT:          s=VoIP d=DSP payload 0x65 ssrc 0x44F5236F sequence 0xB89F timestamp 0x32A0
Dec 16 12:35:28.855 GMT:          s=DSP d=VoIP payload 0x65 ssrc 0x44F5236F sequence 0xB89F timestamp 0x32A0
Dec 16 12:35:28.855 GMT:          Pt:101    Evt:9       Pkt:8A 09 60  >> Dec 16 12:35:28.755 GMT:
The first packet says that it is the start of a new NTE digit because it does not have the endbit set (Pkt:0A 06 40 )
  • The second and third packets are repeats of the first packet for redundancy.
  • The fourth packet is a refresh packet with a duration of 50ms (0×0190 = 400 samples * 1sec / 8000 samples).
  • The fifth packet is the endbit packet (84) with a duration of 100ms (0×0320 = 800 samples * 1sec / 8000 samples) (Pkt:8A 09 60)
  • The sixth and seventh packets are redundant packets for packet five.
As you can see on digit 9, this looks okay however this is not the same for the other digits..It  may be that the router is truncating your logs...
So please take a new log and only enable
Also let us know the exact digits pressed
As mentioned above, the output doesnt seem to show all the logs. If needed, please try the following steps to collect the debugs for a test call:
1)            Enter the following commands on the gateway:
                Configure terminal
                No logging console
                No logging monitor
                Logging buffered 5000000 debugging
                no logging rate-limit
                Logging on
                Service timestamp debug datetime local msec
                Service sequence-numbers
                Exit
                Undebug all
                clear log
                term len 0
2)            Make a test call.
3)            After the test call is made then enter the following commands:
                Un all
                Sh log
352
