Community Member
DTMF tones from CUCUM 9 thru H323 GW out SIP trunk not working
  This is the setup.  Currently in lab environment for a client, but needs to go into production
IP Phone -> CUCM 9 -> H323 GW -> SIP Trunk -> Proprietary device -> Analog phone
Calls complete both ways with no issues.  Proprietary devices only uses G711ulaw, so I have configured a xcoder on the H323 GW to transcode to G729 across the WAN link (between the CUCM cluster and the H323 GW).
Pressing keys/sending DTMF tones from the IP phone are not heard in the analog phone
Running a debug voice ccpai inout at the H323 gateway shows me that the DTMF tones are being received the GW and are being sent along.  See below:
Seaport#
Seaport#
Seaport#! Pressing digit "9" on VoIP phone
Seaport#
Seaport#
Seaport#
Seaport#
*Nov  5 15:41:57.637: //1181/00B99D4F0500/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 9 to dstCallId 0x49E
*Nov  5 15:41:57.637: //1181/00B99D4F0500/CCAPI/cc_relay_digit_begin_for_3way_conference:
   Check DTMF relay digit begin for 3way conf
*Nov  5 15:41:57.713: //1181/00B99D4F0500/CCAPI/cc_api_call_digit_end:
*Nov  5 15:41:57.713: //1181/00B99D4F0500/CCAPI/cc_relay_digit_end_for_3way_conference:
   Check DTMF relay digit end for 3way conf
Seaport#
Seaport#! Pressing digit "9" on VoIP phone                " on VoIP phone                 5" on VoIP phone
Seaport#
Seaport#
Seaport#
*Nov  5 15:42:14.913: //1181/00B99D4F0500/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 5 to dstCallId 0x49E
*Nov  5 15:42:14.913: //1181/00B99D4F0500/CCAPI/cc_relay_digit_begin_for_3way_conference:
*Nov  5 15:42:14.989: //1181/00B99D4F0500/CCAPI/cc_api_call_digit_end:
*Nov  5 15:42:14.989: //1181/00B99D4F0500/CCAPI/cc_relay_digit_end_for_3way_conference:
Seaport#
Seaport#! Pressing digit "       5" on VoIP phone
Seaport#
Seaport#
Seaport#
Seaport#
Seaport#
However, debug ccsip does not give me any indications that the DTMF tone is being sent out the SIP trunk.  Debug ccsip all attached.
Relevant portions of the H323 configuration are below
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
interface Loopback0
ip address 172.16.88.254 255.255.255.255
ip pim sparse-dense-mode
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.88.254
interface GigabitEthernet0/1
ip address 192.168.200.254 255.255.255.0
duplex auto
speed auto
interface Loopback0
interface GigabitEthernet0/1                                   <- interface to proprietary device
duplex auto
speed auto
interface GigabitEthernet0/2                                  <-interface to Local LAN supporting IP Phones
ip address 10.10.10.254 255.255.255.0
duplex auto
speed auto
sccp local GigabitEthernet0/2
sccp ccm 10.10.10.254 identifier 1 priority 1 version 3.1
sccp ccm group 1
bind interface GigabitEthernet0/2
associate ccm 1 priority 1
associate profile 10 register xcoder_1
dspfarm profile 10 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 10
associate application SCCP
dial-peer voice 2 voip
          description Default Incoming Dial Peer
incoming called-number .
voice-class codec 1
dtmf-relay h245-alphanumeric h245-signal rtp-nte
dial-peer voice 6 voip
destination-pattern 90052..                      <- DN of analog phone
session protocol sipv2
session target ipv4:192.168.200.1            <- IP of proprietary device
codec g711ulaw
no vad
sip-ua
registrar ipv4:172.16.88.254 expires 3600
no transport tcp
telephony-service
sdspfarm units 4
sdspfarm transcode sessions 2
sdspfarm tag 1 xcoder_1
I also ran the debug voip rtp session named-event all but nothing was displayed when I pressed the digits on the IP Phone.
Jeff
1 REPLY
Please configure "dtmf-relay rtp-nte" command under SIP dial-peers.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
646
