Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Dual IP in CCM Server
Presently i am running 1 CCM publisher with IP 192.168.1.10. Now i want to add one more IP so that both IP;s of different subnets can be reached differently.
IP-1 will be accessed internally from LAN whereas IP-2 will be accessed from outside.
Is this setup feasible.
Need some light in this issue.
Thanks in advance.
Re: Dual IP in CCM Server
Cisco does not recommend having 2 IP addresses on a CCM server. You can do network teaming though.
Check this link:
http://www.cisco.com/en/US/partner/products/hw/voiceapp/ps378/prod_installation_guide09186a0080799d7c.html
It says:"Assigning two IP addresses to the Cisco Unified CallManager server may cause a loss of service."
HTH,
I think the biggest reason here is service binding issues with a particular IP. So they dont recommend using two IPs.
97
