Dual Line ephone-dn roll over to Voicemail if both in use
I was wondering if it is possible for someone with an ephone-dn set as dual line to have a third call roll over to vmail if both are in use?
Any help is appreciated!
Thank you
Hall of Fame Super Silver
Sure, that would be the defaul behavior if you have voicemail configured.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmevmail.html#wp1031671
HTH,
Chris
Green
Sean,
try putting hunt stop channel uner the ephone-dn
ephone-dn  2  dual-line
number 5002
pickup-group 1
call-forward busy 5990
call-forward noan 5990 timeout 15
huntstop channel
Alex
Regards, Alex. Please rate useful posts.
I do have voicemail configured and I do have huntstop on.
I also have it set to go to my vmail extension in the CFNA.
Sean,
So what are you hearing on the 3rd call?
Chris
3rd call is a busy signal
Can you post your full config?
What happens when you press the Messages button?
Chris
Right now I can't post the full config, but I will try to later.
When you press the messages button it all works as it should.
366
