11-27-2010 03:04 AM - edited 03-16-2019 02:08 AM
Dear Frinds,
We configured 7911-G IP Phone in CME using Dual Line.Now we want to integrate this IP Phones with Call Manager 7.1.5.But i am able to configure one Line for these IP Phone in Call Manager.I need to give two Line (two DN) for these IP Phone. How can i give the second DN in Call Mnaager
Configuration for IP Phone in CME.
ephone-dn 44 dual-line
number 130 secondary 750
label 130
description ROOM210 FF
name ROOM130
corlist incoming use900-international
ephone 44
device-security-mode none
mac-address 0025.84E0.BC9A
username "user130" password 80130
type 7911
button 1:44
Solved! Go to Solution.
11-27-2010 08:07 AM
Hi Naisa,
I really like Davids idea here as it will approximate the "overlay" feature
of CME. +5 to David
Another way to accomplish this is to set up the second line as a CTI-RP
(CTI Route Point) within CUCM. Set the Call Forward All on the new CTI-RP
to Line 1 on the 7911.
In our example the 7911 has a DN of 7005 and you want it to also answer calls
for a second lin DN or 5522.
Set up a CTI-RP in CUCM for 5522 and set the CFWDALL on the DN config page
to go to 7005. All calls to 5522 will ring on the 7911 @ 7005.
Cheers!
Rob
11-27-2010 07:28 AM
Hi, there is not option to configure a secondary number for 7911 in CUCM 7.1. I guess you can use a translation pattern.
This is just a suggestion.
hth
David
11-27-2010 08:07 AM
Hi Naisa,
of CME. +5 to David
Cheers!
Rob
