Community Member
Dual Line problem with Cisco IP phone 99XX on CUCM 9.1
Hi, guys,
I tried to configure a device profile for 9971 with two DN lines, and I assigned it to an end user
which I logged in with into a Cisco IP phone 9971, the problem is that once I logged in, I'm finding only
the first DN line, the second is missing.
Knowing that I had the same problem with the 9951 model, I got no problem with 89XX models.
Can you, guys, give me some help regarding this issue?
I really appreciate your help, guys.
Best regards.
1 ACCEPTED SOLUTION
Hi.Try to create another
Hi.
Try to create another Phone Button template dedicated for that UDP. Try also to add the same Phone button template to a physical phone 9971 and try to login there
Carlo
Please rate all helpful posts "The more you help the more you learn"
Did you set the phone button
Did you set the phone button template on the device profile, did you create the 2nd DN on the device profile?
Please rate useful posts.
Community Member
Yes I did set the PBT and the
Yes I did set the PBT and the seconde DN, George.
Hi.
Carlo
Hall of Fame Super Silver
What is the UDP based on, is
What is the UDP based on, is it also 9971 phone?
Keep in mind there is a concept of extension mobility equivalency:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsgd-861-cm/fsem.html#wp1386088
so, if UDP based on a model is different from what you are logging onto some features may not work including line appearances.
Chris
122
