Duplex Mismatch when connecting ip phone with 2950 switch
 When I connect my Cisco IP Phone 7960 with 2950 Switch (any access port within voice vlan), I get the message on Port duplex mismatch but the phone works properly.
 From my switch the speed setting is 100/Full but from the Phone its Auto.
 My Question is when I try to change duplex settings from Phone, it doesn't gives me any option instead only one option available to save so kindly someone tell me the best way to fix this from Phone or do I have to change the duplex from switch to AUTO ?
1 ACCEPTED SOLUTION
Green
Hi,You should always set your
You should always set your swicthport to be AUTO speed & AUTO duplex when connecting to ip phones
int fas 0/XX
speed auto
duplex auto
Try that and see what happens
Alex
Regards, Alex. Please rate useful posts.
Green
int fas 0/XX
speed auto
duplex auto
Alex
Thanks but When I connect
Thanks but When I connect with my Cisco 2950 Switch, I can see the weird kind of language as per my attachment.
It wasn't yesterday when I first configured from scratch but just seen today.
 Switch is working good with Cisco IP phone connected with it.
Green
Hi,That looks like you have
That looks like you have the wrong speed/parity on your console,
The defaults are 9600 -8N1
Alex
Hi, I am using the same
 I am using the same setting and tried with different pc/laptop and cable but same error coming every time :(
 Problem solved, that was the
 Problem solved, that was the console cable issue.
105
