Duplex mismatch with cisco phone 7940
Not sure if this is a bug or something else.
I'm receiving the following msg on the syslog, but both phone and switch are correctly set to AUTO negotiate the duplex and speed.
Dec 21 11:37:01.107 EST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet3/3 (not full duplex), with SEP001360C3E06D Port 1 (full duplex).
After a interface recycle (shut/no shut) it stop.
Any ideas?
Vlad
Green
Re: Duplex mismatch with cisco phone 7940
Which Switch platform and IOS running?
Could you please post your switch port config?
interface FastEthernet3/1
switchport access vlan 10
switchport mode access
switchport voice vlan 20
switchport port-security maximum 3
switchport port-security aging time 1
switchport port-security aging type inactivity
load-interval 60
qos vlan-based
no snmp trap link-status
tx-queue 3
priority high
end
on the phone:
PC Port Disabled NO
SW Port Configuration AUTO
PC Port Configuration AUTO
Hall of Fame Super Gold
Have you tried to just set fixed speed and duplex on the switch port? Unfortunately, duplex negotiation is not 100% reliable.
719
