Duplicate ethernet port on CCM5
I'm searching for a procedure to enable the both ethernet ports on the CCM5. By Default, the second ethernet port is inactive.
Thanks for your help
Re: Duplicate ethernet port on CCM5
Plug both ports in to the switch.
From CLI of Callmanager type the following command,
set network failover enable. (You can use ? after each word for additional options).
Sankar
PS: please remember to rate posts!
Gold
Are u trying to use NIC Teaming ?? Remember, that NIC teaming is not supported on all CM 5.x versoin and HW. It would only work on HP servers with CM 5.0(4) and later
188
