Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Duplicated IP address
                   Hello All,
I Have a problem on Cisco IPphone CP-6961 I got error message that "Duplicated IP address " and I can't access admin setting or network setting on the phone to know which ip address is assign to the phone I can't access anything only i got error message "Duplicated IP address"
Thanks for your support.
1 ACCEPTED SOLUTION
Re:Duplicated IP address
Hello, Mustafa!
You can try to make factory default on this phone.
Sent from Cisco Technical Support Android App
Are you using Static or DHCP?
What is controlling your IP Phones, CUCM or CME?
Do a #sh CDP nei detail on the local switch and it should give you the IP address of the phone.
I use DHCP and CME and #sh CDP nei didn't give me the IP
Do you know the MAC address of the phone? It will be written on it or use the CAM table of the local switch.
Check the DHCP binding table to see what address the phone has using the MAC.
I am guessing you know which port the Cisco phone is plugged into? If so, CDP Neighbour Detail on that port should give you the IP address.
Try "show cdp entry * protocol" to get the IP address of a CDP Neighbor.
On the CME, try sh ip dhcp conflicts. If you see devices listed in the output, do clear ip dhcp conflicts *.
This should take care of your issue.
Please rate helpful answers!
Hello, Mustafa!
VIP Purple
you can try running Wireshark and then, enter ip.addr===x.x.x.x  and search for Duplicate IP address associated with mac-address.
regds,
aman
Thanks all your help i reset phone to factory setting and it solved the problem
797
