Community Member
DX650 No Display
I am facing issue with a new DX650 Phone. When I connect the PoE power the Phone does not boot and it doesn't show anything on the display.
Attached snapshot of the DX650.
Thanks.
BR
Haris Shuja
Everyone's tags (1)
HelloCheck POE switch1- Can
Hello
Check POE switch
1- Can you connect one of your Cisco IP phones which work well with same port which you use for DX650.
Check UTP cable
1-Check to replace the cable with new one
Check switch logs
2- Kindly check logs after you plug your Cisco IP phone  to check the power . use the below
switch(conf)#logging console  " if you logging as console".
or
switch#terminal monitor  " if you logging as telnet or ssh"
please rate all useful information
Community Member
Thank you for your response.-
- I have other DX650 which are working perfectly on the same switch and port.
- Already used multiple cables.
- The DX650 isn't powering on properly.
- When I do show cdp neighbor, it is not being discovered.
- When I do show power inline it is taking 15.4 W when it actually should take 13.7.
- There are no messages on Console except for port up / down and poe.
Thanks.
Hilast test , if you have
last test , if you have external charger try to connect it to your IP Phone?. If you still have the problem , you have to do RMA for this IP phone back to cisco to replace it with new one.
159
