Community Member
dx650 screen lock
We have ip phone dx650. We want disable screen lock for ip phone dx650. Are we able to disable the phone lock screen?
Hi,Have you tried setting it
Have you tried setting it to Always On Mode as per the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cdce/dx600/admin/10_1_1/english/DX60_BK_CFB047D4_00_cisco-dx600-administration-guide-10_1_1/DX60_BK_CFB047D4_00_cisco-dx600-administration-guide-10_1_1_chapter_01000.html#DX60_RF_S1E2D3D7_00
Manish
Community Member
On the device settings do the
On the device settings do the following changes:
Display On Time: Change it to your office starting time or  a bit earlier
Display On Duration: Change it to the end time of your office or a bit extra
Require Screen Lock : Change it to User Controlled>Check the Override Common Settings
Uncheck the setting: Enforce Screen Lock During Display-On TIme >Check the Override Common Settings
Restart the phone.
Now in the setting of the Android OS you will get an option to make it None. Also you can set a pin and then do a manual lock as required by pressing the lock button on the phone,
308
