Community Member
dx650 with be6000 9.0
                   hi all,
i am trying  to register the dx650 phone with BE6000 9.0.1 version.
i downloaded the cop.sgn file for dx650 and device pack ,also i  uploaded both files.
but still i cannot see the dx650 phone in the devices list.
is there any other files required or be6000 9.0 wont support or anyotherway to register the dx650 on BE6k
thanks,
cyril
Purple
Hi Cyril,
Can u share the snapshot of what all Device Pack u have uploaded and phone device list where it is not showing DX650?
Secondly,did u restart the servers after uploading DPs?
regds,
aman
Purple
Hi Cyril,
I was referring the release notes which says
When you apply a Device Package to enable new device support, a cluster-wide reboot is required for those devices to register successfully. A cluster-wide reboot is not required when you apply a Device Package to update
existing firmware/configuration
http://www.cisco.com/web/software/282074299/102824/cmterm-devicepack-9_1_1_21017-2_Readme.pdf
So, u need to restart the servers.
regds,
aman
Community Member
hi aman,
i restarted the be 6000 after upload .
and i dont have any cluster here i have only one CM 9.0 .
apart from that the device package which you mentioned is for 9.1.1 will that work with 9.0.1
here the package which i installed ---- cmterm-devicepack9.0.1.11013-1.cop.sgn
thanks
cyril
Purple
Hi Cyril,
My apologizes.
I checked the datasheet which says DX650 works with BE6000 with 9.1 or later.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps12956/ps12959/data_sheet_c78-726888_ps12956_Products_Data_Sheet.html
secondly, what is the firmware version of DX650?
regds,
aman
Community Member
hi aman,
is it possible to upgrade 9.0 to 9.1 without any license ?
or
we need to have software assurnace from cisco to rehost the license.
is firmware makes any difference on the dx650?
thanks
cyril
Purple
Hi Cyril,
You can do the upgrade .It is just a minor upgrade.No separate license is required.
Make sure u have a valid support contract in case if TAC case needs to be opened for any further help.
If u have firmware 10.0(1.103), then u require Device Pack 9.1.1 else no device pack is required. this is what I see for CUCM else if firmware is 10.0(2.32), no Device pack is required.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
But DP would be last option. First upgrade is required.Just do and update.
regds,
aman
Community Member
hi aman,
i upgraded the BE6k to the following version
System version: 9.1.1.20000-5
but still i cannot see the dx650 in the phone option.
but i didnt try to connect dx650 in the network yet to see if he detects automatically
thanks
cyril
Re: dx650 with be6000 9.0
No, it won't unless the option is under add new, I'm running 9.1.2.10000-28 and I see the option for DX650
I don't see any DevPack compatible with 9.1(1), you'll need to upgrade to 9.1(2) to get support.
EDIT: I found one, 9.1(1) (21026-1), you might want to try and install it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Purple
Hi ,
I checked DX650  comes in CUCM version 9.1.2.10000-28.
I think datasheet should specifically mention the version for BE6K
regds,
aman
352
