Dynamic Cluster Config Enable
Does someone knows what "Dynamic Cluster Config" parameters is about on CUCM?
Everyone's tags (1)
Where do you see this
Where do you see this parameter?
Manish
On the Cisco Unified
On the Cisco Unified Communications Answer File Generator
http://www.cisco.com/web/cuc_afg/index.html
Alex
Hi Alex,There isn't any
Hi Alex,
There isn't any proper documentation available for this parameter, however as per one of the internal links that i could access it refers to auto registration.
Manish
HI ManishInteresting. What
HI Manish
Interesting. What auto-registration is referring to?
Alex
Hi Alex,Please check the
Hi Alex,
Please check the following link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/bccm-712-cm/b02autor.html
Manish
Hi ManishI do know about
Hi Manish
I do know about phone auto registration but that usually set AFTER you install the server on the GUI interface and installation parameters does not affect ip telephone dial plan/registration parameters. Also, to set autoregistration you have to do more than enabling it, you have to configure the extension range for example.
I suspect this is something different related to CUCM node creation inside de cluster (node registration). Node registration needs to be done manually on the publisher. Could you find out more, please?
-Alex
Hi Alex,Even i am not fully
Hi Alex,
Even i am not fully convinced due to lack of any information in any of the forums or database about this parameter. However, i further looked into the sub-parameters under Dynamic-Cluster-Configuration and checked the info about 'Dynamic Cluster Config Timer which is described as - "This field gives information of the timer value set for auto registration post-install. i.e. this sets the widow by which auto registration needs to be done. Otherwise it defaults to the existing way of adding servers to the server table." So, this seems to be referring to server table entries on the Pub.
If you need any further clarity on this, a TAC case would be a good option.
Manish
Hi Manish Thank you.
Hi Manish
Thank you.
329
