E.164 / local and long distance calls
Hello
I'm using E.164 in the global directory and over our system , the cluster is located in Canada
My question how do you do or can tell if the number in the directory is local or long distance number
I need to find a rule for the transformation because our operator does not support adding 1 in front of local calls
This is first time I work with north American dial plan so any hints are welcome
Thank you in advance
Silver
Just use a Called Party Transformation to match \+1.XXX! where XXX is the local area code and strip pre-dot.
Hello
Well but it seems that some other area codes are also considered as local calls
I will find you an example and post it here
First you need to understand dial-plan.
contact a person locally as him how he dials normally like from cell phone or home phone.
then if possible contact service provider and ask for local and LD number ranges.
then create more specific route pattern and then strip  pre dot.
for example say you have loca: 1-555-222-1111, LD: 1-222-333-5555
then for local: 1555XXXXXXX and send that call as local
for LD: 1222XXXXXXX and send that call as LD.
Hope this helps.
Please rate helpful.
Hello
Thank you , I think I did not express my question in a good way
I have a full understanding of how digit manipulation works
when calling the my operator he gave me this link http://www.localcallingguide.com/lca_exch.php?exch=171030
and told me this link wil lgive me the local calls from point of my PRI
My area code 514 my prefix is 403
so is it safe to consider that local calls will always be  514 XXX XXXX
I'm afraid if I take this rule , users will try other area code which supposeed to be local by adding 1 to the begining of the number
or another example maybe some calls will start with 514 but if I change the prefix it will become long Distance
To be honest European Dial plan is easier :-)
its quite difficult to understand.
Let me say,
let user dial anything, but if you know what to send to service provider manipulate digits accordingly.
So if user is dialing 1 or not doesn't make big difference by far when you know its local or long distance call.
If I am not wrong local and long distance will never have same area code.
You have to adjust your dial-plan according to habits of user for dialing as they will not change that overnight.
You should contact local person ask, how they dial.
Normally I follow below questionnaire,
What is your access code for making calls outside the building.(9 or 0)
How are outside emergency services contacted?  Do the users dial 911 or 9-911 directly?
How do you dial station to station internally? 4 digit, 5 digit etc
How are local calls dialed - 9 + 7 digits, 9+1+ 10 digits, 9+10 digits?  Is there a difference between local calls and local cell calls in term of dialing?
How are long distance calls dialed - 9+1+ 10 digits?
How are international calls dialed - 9 + 011+ country code + #?
And accordingly creat RP with digit manupulation.
Hope this helps.
Hello
the problem that some other area code are considered as local calls but it will depend on their prefix
Exampel
say my area code is 514 , call to 330 will be local only if it is 330-249-XXXX
calls to 330-233-XXX is considered as long distance call
I found a good non offfical site to give me all local calls for Monteral please find it below
http://www.localcallingguide.com/lprefix.php?exch=171030&dir=
as you notice it is a pain to optimise this via Regex , so I just made a mass import
Thank you all for your help
328
