02-02-2014 10:38 PM - edited 03-16-2019 09:33 PM
Is there possible to configure E-fax in a call manager?
Once i get a fax it should comes to my email a copy,is this possible task?
Can anybody suggest on this
what are the requirements needed for configuring E-fax,which is the recommended E-fax product with integerated with call manager?
02-02-2014 10:43 PM
Hi Siva,
you need to have third party solution for the same.
Right FAX/GFI are some of the third party solution.
regds,
aman
02-02-2014 11:04 PM
Is it possible we can get a copy of E-fax to email?
07-03-2014 12:28 AM
I recommend to follow this link: http://www.2ring.com/netfax
It's about 2Ring solution which definitely meets your needs.
Moreover, I don't think that only T.37 is what you need. You should use more sophisticated protocols like G.711 or T.38.
HTH,
Martin
02-02-2014 11:03 PM
Hi Siva,
There are third party fax servers available. The protocol used in this would be T.37 off ramp. You need to integrate is to CUCM via a sip trunk. I have posted a link below.
Kindly rate this post accordingly.
http://www.google.co.in/url?sa=t&source=web&cd=3&ved=0CDYQFjAC&url=https%3A%2F%2Fsupportforums.cisco.com%2Fthread%2F345145&ei=_z3vUse3EYiqkQfw6oHoCA&usg=AFQjCNGmLNK_ZaAkT5P1L-1xwix0Yj0bjA
-Kevin
Sent from Cisco Technical Support Android App
02-02-2014 11:27 PM
Yes it is, hence that protocol is called T.37 fax to e-mail.
-Kevin
