Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
E-fax
Is there possible to configure E-fax in a call manager?
Once i get a fax it should comes to my email a copy,is this possible task?
Can anybody suggest on this
what are the requirements needed for configuring E-fax,which is the recommended E-fax product with integerated with call manager?
VIP Purple
E-fax
Hi Siva,
you need to have third party solution for the same.
Right FAX/GFI are some of the third party solution.
regds,
aman
E-fax
Is it possible we can get a copy of E-fax to email?
Re:E-fax
I recommend to follow this link: http://www.2ring.com/netfax
It's about 2Ring solution which definitely meets your needs.
Moreover, I don't think that only T.37 is what you need. You should use more sophisticated protocols like G.711 or T.38.
HTH,
Martin
Re:E-fax
Hi Siva,
There are third party fax servers available. The protocol used in this would be T.37 off ramp. You need to integrate is to CUCM via a sip trunk. I have posted a link below.
Kindly rate this post accordingly.
http://www.google.co.in/url?sa=t&source=web&cd=3&ved=0CDYQFjAC&url=https%3A%2F%2Fsupportforums.cisco.com%2Fthread%2F345145&ei=_z3vUse3EYiqkQfw6oHoCA&usg=AFQjCNGmLNK_ZaAkT5P1L-1xwix0Yj0bjA
-Kevin
Sent from Cisco Technical Support Android App
Re:E-fax
Yes it is, hence that protocol is called T.37 fax to e-mail.
-Kevin
116
