E&M cards in network module
Hi everyone!
I need 2 E&M cards in my 3945 ISRG2.
Scenario:
NM-HD-2V network module with two slots + 2x E&M interface cards (VIC3-2E/M).
I already have one PVDM3-128 in my 3945 router.
Question:
Will this module use the same PVDM, which is present in a router, or I need to buy an additional PVDM and plug it into
NM-HD-2V network module to support these E&M cards?
DSP calculator tells me that I don't need no additional PVDMs, but i'm not sure about it.
Aleksei
Hall of Fame Super Gold
You can install the E&M VICs in the WVIC slots, no need for NM.
Problem is that I'm out of WVIC slots, thus I need NM.
Then use it.
That's what I want.
Question was:
Green
From link
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/Conntvoi.html
Note For the NM-HD-1V, NM-HD-2V, and NM-DS-2VE network modules, DSPs are on-board and are not field-replaceable units (FRUs).
Therefore this unit provides DSPs for you.
Alex
Regards, Alex. Please rate useful posts.
Thank You,
Now it makes sence
Aleksei
Green
Aleski,
The NM-HD-2V only has enough DSP resource for :-
NM-HD-2V
2-slot IP communications voice/fax network module.
Supports up to eight channels of analog/BRI voice using medium complexity codec or six channels using any supported codec. (No support for T1/E1 or data WAN)
Alex
Re: E&M cards in network module
acampbell wrote:
From link
Alex
I think that in this sentence cisco wanted to tell NM-HD-2VE, not NM-DS-2VE. Even in google I didn't found
NM-DS-2VE module.
Aleksei
658
