E&M cards
Hi all,
I have an alcatel IP PABX amd i want to use a cisco E&M card.
Could you please help me to know if the E&M card is compatible with alcatel IP PABX.
1 REPLY
Hall of Fame Super Gold
Re: E&M cards
It is compatible if you have an E&M card in the PBX. Do you have it already and which model is it ?
If you don't have it yet it would be better if you get ISDN BRI instead that will give two channels, has more features and is infinitely easier to configure and troubleshoot.
369
