E&M trunk card compatibility with cisco
i'm just making sure that my proposal would work so i want to ask the experts.
my client is asking for an upgrade, from their old voice router.
Old Hardware
Cisco 1750 Router
Fxs/Fxo module
panasonic Pbx
with:
KX-TDA0184
8-Port E & M Trunk Card (E&M8)
8-port E & M (TIE) trunk card. Type 5 support.
they are planning to upgrade to:
Cisco 2801
2xVIC2-E&M
please tell me if i miss something or if there is a compatibility issue.
rgds,
ben
1 REPLY
Hall of Fame Super Gold
Re: E&M trunk card compatibility with cisco
Yes it should work. You can use the voice bundle that comes already with pvdm2-8.
314
