You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
E1 back to back on same H323 Gateway
I have a test plateforme with to PSTN provider and with only one 2821 voice gateway.
I'd like to simulate the PSTN by linking the 2 E1 controller on the VWIC-2MFT-T1/E1 of my gateway using to E1 cross-cable.
At the beginnig I did in MGCP but it didn't work probably due to CCM loop avoidance mechanism, then I did in H323 but it still not working.
Do you have any idea if it is possible or not?
I attached to conf if you want to have a look.
PS:all test numbers start with 69XXX ,I created a route pattern "*.69XXX" to use the H323 gawteway to force call to go through the GW
  • IP Telephony
Re: E1 back to back on same H323 Gateway
Any ideas ?
Could b every usefull with only 1 voice gateway and no PSTN provider.
Luc
Luc,
For starters, try making the following changes:
dial-peer voice 100
incoming called-number .
dial-peer voice 1
destination-pattern .T
debug isdn q931 should help you see what's happening.
Phil
181
