E1 CAS Problem with AS 5400 XM
Hi All,
I managed to establish E1 CAS connection between Cisco 2800 series router & a 3th party TDM IVR.
With the following commands,
controller E1 0/1/0
framing NO-CRC4
clock source line primary
ds0-group 1 timeslots 1 type fxo-loop-start
ds0-group 2 timeslots 2 type fxo-loop-start
And tried to do the same thing with a AS5400 XM but unfortunatelly “fxo-loop-start” is not supported in AS 5400XM
(config-controller)#ds0-group 0 timeslots 1 type ?
  e&m-fgb              E & M Type II FGB
  e&m-fgd              E & M Type II FGD
  e&m-immediate-start  E & M Immediate Start
  fxs-ground-start     FXS Ground Start
  fxs-loop-start       FXS Loop Start
  none                 Null Signalling for External Call Control
  p7                   P7 Switch
  r2-analog            R2 ITU Q411
  r2-digital           R2 ITU Q421
  r2-lsv181-digital    R2 LSV 181
  r2-pulse             R2 ITU Supplement 7
  sas-ground-start     SAS Ground Start
  sas-loop-start       SAS Loop Start
Which one should i use instead of “ fxo-loop-start “
Thanks for your help.
Everyone's tags (3)
Re: E1 CAS Problem with AS 5400 XM
Have you tried type "R2-digital" for CAS E1 in AS5400XM ? Pl check
Lavanya
Yes i tried it but did not work.
Hall of Fame Super Gold
Must be E1 R2.
Nobody uses "pure" E1 CAS.
421
