E1 flap
My all outgoing calls sometimes come down after less than 1 minute.
I think that the reason of this issue is due to that E1 flap.
I made debug for the E1 and the results are attached.
So, if you please, if any one suggest what is the real reason and if it is from my router side or from the C.O. side.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: E1 flap
Keep monitoring and please remember to rate useful posts with the scrollbox below.
Re: E1 flap
Send "show controllers E1". Do not enable any other debugs.
Re: E1 flap
Please, find attached sh controller e1 as per your request
Re: E1 flap
Configure:
network-clock-select 1 e1 0/1/0
Then check again you must have 0 errors, 0 slips.
Re: E1 flap
sorry, where can i find 0 errors, 0 slips.
Anf if so achieved, the line will not flap again
Re: E1 flap
You must enter the command above first, then check later.
Re: E1 flap
Thx a lot as i entered the command, and no error now.
But, now E1 will not flap again.
Re: E1 flap
253
