E1 freezes over time
woutereelen
The E1 connection will "sometimes' freeze for no obvious reason. Once a month, then maybe 2 times a week, then nothing for 2 months. There is no pattern in this freezes. I have configured everything correct. I have used this setup with the same provider in the same country for other customers where it works without errors.
I have changed everthing on the customers side: voice gateway, IOS, cabling. The provider also has changed everything on their side.
The problem still is there, all the swaps did not solve the problem. I'm running out of ideas.
As you can see, there are some errors.
Does anybody has an idea on what to do next? The provider will tell me next time that he can not do anything else. The customer begins to wonder...
E1 0/3/0 is up.
Applique type is Channelized E1 - balanced
Cablelength is Unknown
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20071011, FPGA: 13, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (856 seconds elapsed):
3 Line Code Violations, 13 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins
1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 6 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
_____________________________________________________________
Serial0/3/0:15 is up, line protocol is up (spoofing)
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Last input 00:00:01, output 00:00:01, output hang never
Last clearing of "show interface" counters 2d04h
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
36516 packets input, 664656 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored, 1 abort
34326 packets output, 200000 bytes, 0 underruns
0 unknown protocol drops
4 carrier transitions
paolo bevilacqua
Can you provide a show controllers E1 when the problem happens ?
Which exact IOS are you using ?
MGCP or H.323 ?
IOS: c2801-spservicesk9-mz.124-21.bin
It's configured as an H.323 gateway.
Recommend you try 12.4(3j) that is known as the most stable.
Beside that, you would need to collect a bunch of info when the problem occurs, and work it with the TAC.
