Community Member
E1 head Number assignment
Hi All,
I've configured my E1 port on cucm but when i try to dial outside i got a dis order tone, when i contact the SP provider they told me that i've to register the head number they game to the e1. please guide me how can i do that ?
best regards
kennedy
1 ACCEPTED SOLUTION
Re: E1 head Number assignment
He does need dial peers and to switch to h323, we do not support partial PRI with MGCP.
java
if this helps, please rate
www.cisco.com/go/pdi
Hall of Fame Super Gold
There is nothing to register with E1.
You can take "debug isdn q931" with "term mon".
Community Member
please see my debug result
when i call from office (E1) to pstn
moencovg#no debug isdn q931
debug isdn q931 is              OFF.
moencovg#debug isdn q931
debug isdn q931 is              ON.
moencovg#
*Oct 11 07:09:25.970: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0002
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98394
                Exclusive, Channel 20
        Calling Party Number i = 0x0081, '+251116170909'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80
*Oct 11 07:09:25.982: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x0155
        Cause i = 0x8292 - No user responding
*Oct 11 07:09:25.982: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8155
        Cause i = 0x80D1 - Invalid call reference value
*Oct 11 07:09:26.970: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8155
*Oct 11 07:09:29.982: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0002
        Sending Complete
                Standard = CCITT
*Oct 11 07:09:30.982: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0002
        Sending Complete
                Standard = CCITT
*Oct 11 07:09:34.002: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0002
        Cause i = 0x80E6 - Recovery on timer expiry
*Oct 11 07:09:35.002: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0002
when i call from pstn to office (E1)
moencovg#
*Oct 11 07:06:52.330: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0155
                Standard = CCITT
        Channel ID i = 0xA9838F
                Exclusive, Channel 15
        Calling Party Number i = 0x4183, '912195132'
                Plan:ISDN, Type:Subscriber(local)
        Called Party Number i = 0xC1, '0116170909'
*Oct 11 07:06:52.338: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8155
        Cause i = 0x809B - Destination out of order
*Oct 11 07:06:53.338: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8155
*Oct 11 07:06:54.862: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0155
                Standard = CCITT
*Oct 11 07:06:54.866: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8155
*Oct 11 07:06:55.866: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8155
*Oct 11 07:06:58.858: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0155
        Cause i = 0x82E6 - Recovery on timer expiry
*Oct 11 07:06:58.858: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8155
*Oct 11 07:06:59.858: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8155
Community Member
Any updates ?
Hi kennedy,
Incase of outgoing call you are sending called number as blank. Please check your configuration.
Which protocol you are using? What is the call flow?
can you share network topology?
Also share your running config of your Voice gateway
Nishant Savalia
Regards, Nishant Savalia
Community Member
Hi Nishant,
protocol is MGCP
running config is attached below but i didn't create any dial peer for e1 is it a must ? please help me coz i have no one beside me here
You have the wrong configuration in CUCN and /or router, that is the number translations are wrong.
Recommend you get a reputable consultant ot Certified Cisco partner for this, do not attempt to do yourself.
Community Member
but idid not do translations and i don't have a consultant
Community Member
You seem to be missing some/lot of configuration. You might have your e1 configured, but i dont think you have dial peers configured on the gateway for incoming calls and for outbound there is something else missing.
Can you post your router configuration. If something simple can be done, will try to help you, else, like Paolo mentioned, you need to hire someone to knows this well.
Community Member
please see below my router config
moencovg#sh run
Building configuration...
Current configuration : 7536 bytes
! Last configuration change at 08:29:53 UTC Fri Oct 11 2013 by admin
version 15.2
hostname moencovg
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
enable secret 4 c5LFTnp3A5C3Ds2sCA3PU0Csl6Q1V1MpHyKNktEi5tI
no aaa new-model
network-clock-participate wic 0
ip cef
ip dhcp excluded-address 10.10.10.1
ip domain name moenco.corp
ip name-server 172.20.0.23
no ipv6 cef
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-3990007969
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3990007969
revocation-check none
rsakeypair TP-self-signed-3990007969
crypto pki certificate chain TP-self-signed-3990007969
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393930 30303739 3639301E 170D3133 30363139 30373030
  30385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39393030
  30373936 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100E6F7 448AA926 A7D8AAD8 D3488CFF F2928A99 E7A427F1 6EFEC5F6 0706E9B8
  505657CE 98499BD6 9D7D21AF 55718077 077128E1 21C8DFD4 CD1E9F79 D161DEBC
  D107795F BDB1E908 582C3140 A4F1FBC2 00C75850 28A3309F 84F229D0 95BD7ADE
  121CF969 275BF813 048504D4 9D12A4B7 2A724A78 CF02A15F 29927BC8 39F5482C
  F8130203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14B41221 0B2A24EC A4EB7BC8 74DD5344 87E4A0BF BD301D06
  03551D0E 04160414 B412210B 2A24ECA4 EB7BC874 DD534487 E4A0BFBD 300D0609
  2A864886 F70D0101 05050003 81810072 33910E76 9A03BBBF FDCFD9F5 C384A55B
  D6D7E295 03AD17F8 4F7AF038 5A694E57 8A8858C4 61F10181 28C7CD37 FDAD2D1C
  56CAD1D6 31AAE479 773A5807 61C136D4 EE6646A9 D7153DE9 DADB4414 68DAC5D9
  3DDA1AED 6712F942 4000B818 D7424520 CBBCF430 1748A277 C1AB92C3 08905875
  430F1134 6C192164 81BD656D 398B82
        quit
voice-card 0
license udi pid CISCO2921/K9 sn FCZ172560ED
hw-module pvdm 0/0
username XXXX privilege 15 password 0 XXXX
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-20 service mgcp
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.20.0.49 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip default-gateway 172.20.0.11
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
timing hookflash-out 50
timing guard-out 1000
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.20.0.41
ccm-manager config
mgcp
mgcp call-agent 172.20.0.41 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
dial-peer voice 999030 pots
service mgcpapp
port 0/3/0
dial-peer voice 999031 pots
service mgcpapp
port 0/3/1
dial-peer voice 999032 pots
service mgcpapp
port 0/3/2
dial-peer voice 999033 pots
service mgcpapp
port 0/3/3
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
dial-peer voice 999012 pots
service mgcpapp
port 0/1/2
dial-peer voice 999013 pots
service mgcpapp
port 0/1/3
gatekeeper
shutdown
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
password XXXX
login
transport input telnet ssh
line vty 5 10
access-class 23 in
privilege level 15
password XXXX
login local
line vty 11 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Suggest remove the mgcp configuration and re configure like the below
Check if the mgcp is registered into cucm
show ccm-manager to check the status
If is not registered then issue no mgcp and then mgcp
controller E1 0/0/0
framing NO-CRC4
ccm-manager switchback immediate
ccm-manager fallback-mgcp
ccm-manager mgcp
mgcp
mgcp call-agent 172.20.0.41 service-type mgcp version 0.1
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn outgoing display-ie
isdn outgoing ie redirecting-number
no cdp enable
Please rate all useful posts
Chrysostomos
""The Most Successful People Are Those Who Are Good At Plan B""
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Community Member
First of all, please remove the passwords from your configuration before you upload it to some forum. Would recommend editting your post and removing them.
Looking at your configuration, you are using MGCP and therefore there would be no digit manupulation being done on the Gateway. All digit manupulation would be done on CUCM.
What is route pattern that you have on CUCM and what is the discard digits configured to be on CUCM ?
Community Member
Hi, thanks for your advise
My route pattern is 7.XXXXXXXXXX for national/local calls, anf discard predot
is it a must to configure dial peer for E1 on the gateway ?
Community Member
any updates ?
You dont need a dial peer into the VG if is mgcp config
R you sure that you send the correct A number to the provider?
Chrysostomos
Community Member
what is A number ? and how do you configure it ?
Hi Kennedy
please follow the below:-
1- you need to reconfigure your VG as MR/Chrysostomos advise above , please take the above configuration which he already postes.There will be no configuration requred on yr GW.
2-On your CUCM , please go to your GW and check if your GW is registered .Please screen shot for the screenshot for your GW configuration on your CUCM.
3-Configure route group which will contain the registered Gateway.
4-Configure Route list which will include the configured RG on step 3.
5-Configure route pattern which will match  your dialed number. use 9.XXXXXXXX as example and predot.
6-before dial any number check the below on your VG
show isdn status , sh ccm-manager
7- dial a call and test
thank you
please rate all useful information
Community Member
java
Jaime
Where is documented  that
And why is not supported
I agree with you that h323 or sip is better but ....
Chrysostomos
chrysostomos1980 wrote:
Jaime
Documented in many places, just do a search.
Ok
Its not supported but it has a workaround about that
Agree with you also that h323 is the best solution here
set "enable status poll" parameter on the ccm. (cc gateway configuration)
2. on the ccm service parameter: change in advanced mode and fill out the "B-Channel Maintenance Status " field.
this could be:
S0/DS1-0@0123456789ABC = 0000 0000 0111 1111 1111 1111 1111 1111 (32 bits for E1 or 24 for T1).
0-means in Service
1-means out of Service
The signalling channels (15-E1 or 23-T1) are not affected.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008076f8d2.shtml
Community Member
@Java: You can still do it by putting your B Channel out of service and the current command it works with the new IOS. Not officially supported, but this is how it is accepted and heard it is now valid for different testing as well.
I dont think this is an issue with the Gateway. The gateway is sending the call out. The problem is with the calling number being sent out. The outbound call does not send called number and therefore the call would fail.
Can you please share the snapshot of Route Pattern which you are hitting. Also, can you run dial plan report for the number you are dialing.
Community Member
Hi All,
Do i have to configure my E1 port for loop start or ground start on the MGCP gateway to be able to call to PSTN ?
best regards
Kennedy
Community Member
Neither, E1 PRI is a TDM circuit. Loop start and ground start are specific to analog trunks such as FXO and FXS.
Community Member
when i call from my cell phone to the office (E1) i can see that my number got reached at the gateway by debugging. so what did i do wrong ? is ther a special configuration for E1 to to call to pstn ? please help
464
