Community Member
E1 interface not coming up
my E1 interface is not coming up ,not reciving any signal from outside .please find my debug and show coommand.
anybody can tell me what will be the cause , is it hysical connection probelm or any configuration issue.
sho controllers E1 0/2/0
Serial0/2/0:15 is down, line protocol is down
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Last input never, output never, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 carrier transitions
Timeslot(s) Used:16, SCC: 0, Transmitter delay is 0 flags
sho isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
dsl 1, interface ISDN Switchtype = primary-net5
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 1 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 1
Total Allocated ISDN CCBs = 0
Hall of Fame Super Gold
Re: E1 interface not coming up
You haven't put the complete show controllers ?
Check cabling to telco termination, what is that ?
Community Member
Thanks ,
From telco interface is DB 15 and cisco router interface is RJ45
And telco Side they came and tested the loop and whyle testing loop they told me when my router is connected to NT box they are not reciving any signal over there but once i removed this cable from NT box and then they recived .
colud you please tell me what wil be the reason , is there any thing wrong with the cable, interfaces
Prajoth Janadas
Hi, you may be using the wrong cable, check pinout as documented in the VWIC installation manual. Then as mentioned above you need to post the complete output of "show controllers E1".
Community Member
thanks,
i changed the cable and now i can see the status is up but ot able to make any calls or reciving any calls
even i lost my secondery dialton
Prajoth
Hi, your isdn is not fully up yet, when it is, it will show "multiframe established".
You must configure "network-clock-participate wic 0" and "network-clock-select 1 e1 0/0/0".
After that ask telco to restart service on the switch and further calling issues can be looked at.
Silver
just to add to Paulo nice posts, if physical setup and cabling is ok and E1 is activated and ready by telco, try to check the correct isdn switch type and if you have a CCM then make sure you are assigning the correct isdn switch type under Gateway configuration as well
hth
/majdi
213
