E1 Internet Acces
Is there any chance or a way to know to configure and E1 to have Internet or WAN Access?
2 ACCEPTED SOLUTIONS
Hi.Here is a post where you
Hi.
Here is a post where you can take some tips.
https://supportforums.cisco.com/discussion/11878866/ccie-voice-lab-question#3996293
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.Basically you need to
Hi.
Basically you need to configure your E1 Controller as per ISP specs than configure serial interface with desired encapsulation and treat the serial interface serial0/0/0:0 as a data interface.
Here is a useful link
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/shared_port_adapters/configuration/ASR1000/ASRspasw/asrcfgt1.html#pgfId-1175321
Carlo
This is a voice forum, you
This is a voice forum, you should be posting this in a WAN forum.
java
if this helps, please rate
www.cisco.com/go/pdi
Hi.
Carlo
Carlo, Thanks for you help,
Carlo,
Thanks for your help, but I have one more question, I don't see how I can do this configuration. Do you have any example to look at?
Thanks.
Hi.
Carlo
26
