E1 is down
Hi Guys,
I am configuring one e1 pri. I have given the configuration below. But it is showing down. Kindly help. I read that this error is due to wrong cable? I have used an straight ethernet cable.
Thanks in advance.
ERROR:
CME#show controllers e1
E1 0/1/0 is down.
  Applique type is Channelized E1 - balanced
  Transmitter is sending remote alarm.
  Receiver has loss of signal.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (465 seconds elapsed):
     9105 Line Code Violations, 20 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 465 Unavail Secs
  Total Data (last 22 15 minute intervals):
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 19800 Unavail Secs
CONFIGURATION:
card type e1 0 1
logging buffered 5000000
enable password cisco
no aaa new-model
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
isdn switch-type primary-net5
controller E1 0/1/0
pri-group timeslots 1-31
interface Serial0/1/0:15
no ip address
encapsulation ppp
isdn incoming-voice voice
Hall of Fame Super Silver
E1 is down
Controller DOWN indicates either carrier detect issue or physical connectivity issues. make sure cable is connected, carrier detect light is ON, if not try different cable, if no go check with service provider if they can loop onto the circuit.
HTH,
Chris
E1 is down
Thank you Chris..
I tried using different ethernet cables. But still its the same. Further in a doc I read that the cable should be a cross over one. Is it true we need to use a cross over cable? I have given the link to the doc below. Else I may need to contact with the provider itself.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800fb754.shtml
Thanks a lot..
Re: E1 is down
There is no reasons to check ISDN status when controller is down. On Cisco side first pair (1, 2) is RX and second (4, 5) is TX or vice versa. Search "E1 pinout" on cisco.com to find exact pinout for your model.
Re: E1 is down
typically you do not need crossover cable between the gateway and smart jack, but you can try. What lights do you see on the smart jack?
E1 is down
On the back side of the router on the e1/t1 card there is one amber color and yellow color led glowing.
E1 is down
Not sure if you already checked this, but ensure E1 pinouts are as follows
1 <-> 4
2 <-> 5
4 <-> 1
5 <-> 2
Hall of Fame Super Gold
E1 is down
That is wrong.
It must be a straight T1 cable, with the pinout indicated in the documention.
However the most common cable, is circuit failure.
E1 is down
Please post output of
show isdn status
If Layer 1 is down or deactivate then the problem is physical (cable)
if Layer 2 is down then the problem could be combination of framing,linecode, you seem to have alot of linecode violations
Also verify the configs from the otherside
isdn switch-type protocol or timeslot issues
What we may need is a E1 cross-over not an Ethernet cross-over cable(E1 G703).
Remember that Ethernet cables pinout is 1,2,3,6 whereas E1 G703 pinout is 1,2,4,5
Maybe this may be of some assistance,
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b6e0f.shtml
Good Luck!
E1 is down
Thanks for replying. I have given the output of show isdn status
mdxin-2901cmx#show isdn status
Global ISDN Switchtype = primary-net5
ISDN BRI0/0/0 interface
        dsl 0, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        SHUTDOWN
    Layer 2 Status:
        Layer 2 NOT Activated
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
ISDN Serial0/1/0:15 interface
        dsl 1, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
    Active dsl 1 CCBs = 0
    Number of L2 Discards = 0, L2 Session ID = 0
    Total Allocated ISDN CCBs = 0
    Layer 1 Status:
        SHUTDOWN
    Layer 2 Status:
    Layer 3 Status:
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
    Layer 3 Status:
E1 is down
OK,
If you look at Layer 1 below you will see that its shutdown and deactivated. You might have a cable issue between telco switch and your e1 card follow the doc below as a guide for E1 cable type
Layer 1 Status:
        SHUTDOWN
    Layer 2 Status:
    Layer 3 Status:
    Layer 1 Status:
        DEACTIVATED
E1 is down
Thanks again.
Here I have one doubt. I have configured e1 pri. and in the output of show isdn status, it is showing the status of BRI. Right? The router has a BRI card too. But I have not configured it.
I would call the pstn providers and check tat too.
E1 is down
to answer your question even though it is showing the status of the BRI interface the state is shutdown and the serial interface is the one you have configured. but you still have a cable issue on there interface becasue its deactivated.
so in this case you are working with the correct interface
    Layer 1 Status:
        SHUTDOWN
    Layer 2 Status:
    Layer 3 Status:
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
    Layer 3 Status:
1946
