E1 ISDN problems
All,
Could anyone help me?
I wonder what would be an example of a configuration to meet voice E1 ISDN (30 channels) PCM31C.
Important information:
Show version:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M1, REL        EASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 14-Jun-11 19:25 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M12, RELEASE SOFTWARE (fc1)
RT-SPO-01 uptime is 2 hours, 23 minutes
System restarted at 13:52:49 PCTime Wed Dec 21 2011
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M1.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FTX1537AH89
3 Gigabit Ethernet interfaces
31 Serial interfaces
2 Serial(sync/async) interfaces
1 terminal line
1 Channelized E1/PRI port
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255744K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FTX1537AH89
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
Conf:
card type e1 0 0
network-clock-participate wic 0
isdn switch-type primary-net5
voice-card 0
controller E1 0/0/0
pri-group timeslots 1-31
interface Serial0/0/0:15
no ip address
encapsulation hdlc
shutdown
isdn incoming-voice voice
fair-queue
no cdp enable
voice-port 0/0/0:15
cptone BR
dial-peer voice 10 pots
description Saida PSTN
destination-pattern 0T
incoming called-number .
direct-inward-dial
port 0/0/0:15
I'm with errors in the interface and do not receive calls over the public network.
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (220 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     5 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     5 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 1:
     18 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     18 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 1 15 minute intervals):
     0 Line Code Violations, 0 Path Code Violations,
     18 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
Luciane de Medeiros
1 ACCEPTED SOLUTION
Green
E1 ISDN problems
Add
network-clock-select 1 E1 0/0/0
int s0/0/0:15
no shut
Alex
Regards, Alex. Please rate useful posts.
Re: E1 ISDN problems
That's right, you can not receive calls while s0/0/0:15 shutdown.
Regards, Maxim
E1 ISDN problems
Oops!
I ended up sending the configuration before executing the "no shut", but is not the reason for the failure. ;-) It was just forgotten. I set the "network-clock-select 1 E1 0/0/0" as the tip of Alex, and I will test.
Thank you!
Luciane
Green
E1 ISDN problems
Add
int s0/0/0:15
no shut
Alex
E1 ISDN problems
Oops!
Thank you!
Luciane
In this case you should first check sh isdn ststus output for the layer 2 state, it should multiple frames established. If that state differs check the switch type and user/network configuration, you can see details in debug isdn q921.
If layer 2 state is correct check the debug isdn q931 and show call hist voice output.
Regards, Maxim
E1 ISDN problems
I set the "network-clock-select 1 E1 0/0/0" as the tip of Alex. It worked!
Thanks for all,
Luciane
572
