06-11-2012 12:20 AM - edited 03-16-2019 11:36 AM
Subject: E1-To-NortelPABX-To-PSTN Migration To E1-Directly-Connected-To-PSTN
what are the things and configuration to be considered for the implementation of the abovementioned subject?
looking forward to hear from you soon
thanks and best regards,
06-11-2012 12:28 AM
Hi.
1st you have to see which protocol you want to run.
Is it MGCP or H323.
if you are using MGCP, you will have to do changes in CUCM and Router level. And if you are using h.323 , mostly you will have to do changes in router only.
regards
Ronak patel
Rate helpful posts by clicking stars below the answer.
06-11-2012 01:26 AM
actually we are running H323...any additional information?
06-11-2012 01:30 AM
You need to do following
1) re do your router configuration for E1 connectivity with Service provider. ( remove old config and add Service provider specific configuration )
2) May be you will have to change dialpeers as per your routing rules.
regards
Ronak patel
Rate all helpful posts by clicking stars below the answer.
06-11-2012 01:33 AM
you mean ...like signalling and stuff like that..that is to say i have to coordinate with PSTN provider for configuratio?
06-11-2012 01:38 AM
Yes, Like what switch type to use, what framing type to use etc.
Ronak patel
