Community Member
e1 or p1 or pri?
hi.. what is the common implementation to connect pbx with cisco router? is the connection actualy just by plugging short cable? what necessary frame/signaling needed? i mean something like pri,unframed/framed/channnilized? would please give me understanding what is it and how to configure them so i can make pabx trunk to router to router then to pabx trunk. i am glad if you give cisco doc that make it happen.. :)
1 REPLY
Bronze
Re: e1 or p1 or pri?
My recommendation would be to use QSIG which is a variant of ISDN signaling. QSIG is supported on most cisco router platforms. The cabling could be a t1/e1 cable (possibly t1/e1 crossover cable) from router to pbx.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a008020ece4.html#wp1037888
109
