E1 PRI. Calls to PSTN and from PSTN are not connected.
vyacheslav.k
there is a following structure: PSTN <-E1 PRI-> 5350 <-IP-> SoftSwitch
The problem is the calls from IP tel to PSTN go out, but connections are not established. The same situation with calls from PSTN to IP.
IP tel (PSTN numbet) is 577011
PSTN (city) number for testing calls is 549079
Mobile number for testing calls is 9230761245
PSTN station takes 10 digits in number and returns 6 digits (if it's a local number) and 10 digits in other cases.
I made some test calls and put it in a file which I attached.
Here is config of 5350:
192.168.1.20 is a SoftSwitch
isdn switch-type primary-net5
voice rtp send-recv
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711alaw
voip-incoming translation-rule called 10
controller E1 3/0
framing NO-CRC4
pri-group timeslots 1-31
cablelength long
controller E1 3/1
translation-rule 10
Rule 1 ^1 1 ANY national
Rule 2 ^2 2 ANY national
Rule 3 ^3 3 ANY national
Rule 4 ^4 4 ANY national
Rule 5 ^5 5 ANY national
Rule 6 ^6 6 ANY national
Rule 7 ^7 7 ANY national
Rule 8 ^8 8 ANY national
Rule 10 ^9 9 ANY national
translation-rule 11
translation-rule 1
Rule 1 577011 111
interface GigabitEthernet0/0
ip address 192.168.1.13 255.255.255.0
duplex auto
speed auto
negotiation auto
no cdp enable
interface Serial3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice modem
isdn map address .* plan isdn type national
isdn send-alerting
no fair-queue
no cdp enable
interface Async1/00
no ip address
encapsulation slip
interface Async1/59
no ip address
encapsulation slip
interface Group-Async0
no ip address
encapsulation slip
no group-range
voice-port 3/0:D
cptone RU
dial-peer voice 5 voip
huntstop
destination-pattern 1..
session target ipv4:192.168.1.20
no vad
dial-peer voice 10 pots
numbering-type national
destination-pattern .T
no digit-strip
direct-inward-dial
port 3/0:D
dial-peer voice 5770 voip
huntstop
destination-pattern 577011
translate-outgoing called 1
voice-class codec 1
no vad
I would appreciate if you help me. Thanks!
13 Replies 13
paolo bevilacqua
Something is very wrong with the PSTN circuit, because GW sends setups many times, but never receives a reply.
Then you see recovery on timer expiry.
Of course telco will say everything is ok, but they do that all the time.
The PSTN station engineer says that on PSTN everything is ok and something wrong with my device as it sends setup twice or more.
What should I do in this case? Ask the engineer to check their circuit?
Tell him that you device sends setup twice, because it doesn't receive a reply within 1 sec, as dictated by the standards.
These telco types are all the same.
As I understand for normal SETUP the Telco and 5350 must have different types: NETWORK and USER, is not it? Maybe is the problem in this conflicts? How to manually set a type (NETWORK or USER) on 5305, which command (just to know)?
Your setup is right, if you was to use
"isdn protocol-emulate network", L2 does not comes up. Just say you don't pay until it works.
Please remember to rate useful posts with the scrollbox below.
I found out an interesting thing.
I tried to call twice to PSTN number. First attempt was not successful, answer for SETUP did not come to cisco 5350. But, the first attempt was successful and connection between phones was established. Telco enginner says that he sees only one attempt for connect (which was normal).
Then I tried to call to mobile phone. I did it three times. Result:
1 attempt: unsuccessful, the SETUP reply did not come to cisco 5350
2 attempt: successful
3 attempt: successful
In this case Telco enginner says that he sees only 2 attempts for connet (which were successful).
So what happens? Why the first attempts to establish SETUP are incorrect and Telco engineer did not see them? What should I do to find the problem?
Check circuit, for errors on serial interface.
Do you mean: show int serial 3:0/15 or some debug command? Sorry, I'm newbie in it that's why I don't know exactly how to check it. Maybe there is a document how to do it.
show controller e1 ?
#sh controllers e1
E1 3/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info of slot 3: HW: 519, PLD Rev: 6
Framer Version: 0x9
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x0A,
Board Hardware Version 2.7, Item Number 73-5268-03,
Board Revision A1, Serial Number JAE1006VCEK,
PLD/ISP Version 3.0, Manufacture Date 3-Feb-2006.
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (376 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
E1 3/1 is down.
Far End Block Errors Detected
Receiver has loss of signal.
Framer Version: 0x9
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (378 seconds elapsed):
0 Slip Secs, 378 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 378 Unavail Secs
0 Slip Secs, 86400 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
Has the carrier specified no CRC framing ?
sorry if thats a bit vague, i'm just comparing it to current configurations and that is the only difference that i can see.
Yep, it has.
The interesting thing is that when a call is unsuccessful I see signaling layer 2 brokes:
(debug isdn q931, debug isdn q921)
Nov 2 10:01:02.434: ISDN Se3/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=0
Nov 2 10:01:02.438: ISDN Se3/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=0
Nov 2 10:01:12.438: ISDN Se3/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=0
Nov 2 10:01:12.442: ISDN Se3/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=0
Nov 2 10:01:15.794: ISDN Se3/0:15 Q931: Applying typeplan for sw-type 0x12 is 0
x2 0x1, Calling num 3878577011
x2 0x1, Called num 549079
Nov 2 10:01:15.794: ISDN Se3/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=0 nr=0
Nov 2 10:01:15.798: ISDN Se3/0:15 Q931: SETUP pd = 8 callref = 0x00D2
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2182, '3878577011'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '549079'
Nov 2 10:01:16.794: ISDN Se3/0:15 Q921: S7_T200_EXPIRY: VA = 0, VS = 1
Nov 2 10:01:16.794: ISDN Se3/0:15 Q921: User TX -> INFOp sapi=0 tei=0, ns=0 nr=
Nov 2 10:01:16.794: ISDN Se3/0:15 Q931: SETUP pd = 8 callref = 0x00D2
Standard = CCITT
Nov 2 10:01:17.794: ISDN Se3/0:15 Q921: User TX -> INFOp sapi=0 tei=0, ns=0 nr=
Nov 2 10:01:17.794: ISDN Se3/0:15 Q931: SETUP pd = 8 callref = 0x00D2
Standard = CCITT
Nov 2 10:01:18.794: ISDN Se3/0:15 Q921: User TX -> INFOp sapi=0 tei=0, ns=0 nr=
1 second later after signalization sent SETUP we see:
but how to set T200 timer to another value? there is no command like that:
(conf)# isdn timer T200
You can go around and around on this, but unless telco fixes either circuit or their equipment, nothing will work.
Router is ok, they are not but do not admit, same story all the time.
