Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
E1 PRI Channels
I dont know what i am asking is correct but customer requested me.
I have 1 No's  PRI with 150 DID, I have a 30 No's VIP person who want's dedicated each channel, In other words if they want to dial they should not get busy tone or their incoming call should be priortize first,
Is it this possible in E1 PRI.
2 ACCEPTED SOLUTIONS
VIP Purple
E1 PRI Channels
Hi Jack,
at one point of time ,only 30 channels would  be active[incoming or outgoing] i.e. 30 DID numbers from pool of 150 numbers alloted from Service provider.
regds,
aman
VIP Super Bronze
E1 PRI Channels
Jack,
This is a difficult thing to achieve and I certainly will not recommend it. This is because to configure this you need to create atleast 30 different trunk-groups and assign them to a time slot on the PRI. Once thats done, assuming you are using CUCM, you need then create a different CSS, different route lists for each VIP. You will then need to confiure a different dial-peer for each VIP and send the call out to a dedicated channel on the PRI...As you can see thats very cumbersome.
This is only even possible with only outbound cals, you cant control how inbound calls are routed because thats done from your Telco...
I will advise that you tell your customer this is not possible. Its not how the system is designed to work. Thats my 2 cents
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Purple
E1 PRI Channels
Hi Jack,
regds,
aman
VIP Super Bronze
E1 PRI Channels
Jack,
Re: E1 PRI Channels
Thanks to both
+5 aokan very good explanaton to convince customer.
167
