E1 PRI Disconnect problem
Dear all experts,
I have tie line E1 PRI with NEC PBX. There were a few call that active for very long period up to 2 Weeks. I wonder why is this happening with E1 connection, i know it is very common to find this problem on FXO port. I looked into Controller E1 detail and found no clock slip error. Show int s0/0/0:15 also found no error. Could any one tell me what could be the problem here.
Please see the Logg file in the attachment.
Thanks so much!
Prachaya
Hall of Fame Super Gold
Re: E1 PRI Disconnect problem
Stale calls are typically IOS bugs.
Reload and possibly upgrade IOS.
Thanks for you reply. I will try to upgrade the IOS but it will take sometime to see the result because I need some downtime as well to do that. Anyway, will let you once I know the result.
Thanks!!!
208
