09-05-2013 06:45 AM - edited 03-16-2019 07:13 PM
I have 4 E1 Pri links with different DID terminating on 2 no'sVoice Gateway. How I should plan on CUCM 8.6 so that the users of specific DID should flow from his E1 PRI link.
Please explain
Solved! Go to Solution.
09-05-2013 11:57 AM
Ok. Let's try to be a little bit clearer :)
Let's assume you have a user John with extension 1000 and he wants to appear as 1234561000 to outside user phone.
Assume that did 123456XXXX is provided from the PRI link attached on port 0/0/0 of your VG.
Make sure you have correcly added your vg on Cucm
-Configure a partition eg Out_John
-Configure a Calling Search Space Eg CSS_Out_John end include previously configured partition and all other partition needed to reach other internal Extension and/or other service numbers (eg voicemail)
- Configure a route pattern such as 9.!
-on called party transformation mask select discard ditgits pre-dot option
- on prefix digit insert a prefix such as 1070
- select your h323 gateway and click add
-----on your vg------
configure a dialpeer as follows.
dial-peer voice 10 pots
destination-pattern 1070T
port 0/0/0:15
You shold use the above example for each user that need to use a particula DID changing each time partition,css, prefix and so on
Carlo
09-20-2013 11:10 PM
Hi Jack.
If you see at my previous post, the tranlation rule 2 is defined as called not calling on translation profile CALLID
Carlo
09-23-2013 05:32 AM
Hi Jack.
voice translation-profile DID
translate calling 1
Modify the translation profile as reported above, and you'll see it working.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
09-05-2013 07:06 AM
Hi Jack.
From CUCM side you can work with Partition-CSS-Route List to call outside matchig the right VG with the right PRI and applying prefix that would be matched from the VG.
On VG , configuring dial-peers matching the previously configured prefix.
This is only one of different solutions.
Carlo
09-05-2013 07:36 AM
It all depends on what protocol you'll use and you're not mentioning that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-05-2013 08:10 AM
Dear
I will use H.323
09-05-2013 08:35 AM
Then as Carlo mentioned, it all comes down to prefixes and matching them in the dial-peers
java
09-05-2013 11:38 AM
I didnt understood the professional words from the expert, can you you elaborate more in steps.
09-05-2013 11:45 AM
RP 9.@
PT customerA
prefix 12345
dial-peer voice 100 pots
destination-pattern 12345.T
port 0/3/0:15
And so on to match calls on each E1
Segregate via CSS/partitions in CUCM, add prefix, then match that prefix with a dial-peer tied to a port on ISR.
This has been discussed many times before, you can do a quick search to find a lot more info.
java
09-05-2013 11:57 AM
port 0/0/0:15
Carlo
09-06-2013 08:48 AM
Hello Carlo,
Thank you very much for elaboratng more. I will just confrm what I understood from your above words.
For example PRI-A
Now the VG will receive 10 digits, 8 digits the actual which user is dialling and we added 2 more (11) for segragating from other PRI's, suppose my block is for PRI-A is 22222000 to 22222199 then how the translation profiles will be created ?? ITSP is accepting 8 digits and forwarding towards me 8 digits.
09-06-2013 09:23 AM
Hi.
In your vg you wil configure a dial peer pots as
destination-pattern 11T (where 11 is the prefix applied on route pattern on cucm)
port 0/0/0:15
by default vg discards declared digits and , in your case, 11 would be discarded and only 8 digits would be sent to your provider without applying any translation
Carlo
09-06-2013 10:01 AM
Thanks Carlo,
Sorry Carlo, I made a mistake i will have a 4 digit extension on phones so the VG will receive 6 dgits (112001) how i shld configure the translation profile ?? I want to remove 11 before going to ITSP
Could you explain me why 11 would be discarded ?? if it is dot .T then everthing will be discarded before T , but if i put 11T then 11 will go with extension 112001
dial-peer voice 4 pots
translation-profile outgoing CALLID
destination-pattern .T
port 0/0/0:15
forward-digits all
The Below translation profile.
voice translation-rule 1
rule 1 /^2222\(2...\)$/ /\1/
voice translation-rule 2
rule 1 /^\(112...\)$/ /2222\1/ ----- I wanna remove 11 before going to ITSP
voice translation-profile CALLID
translate calling 2
translate called 1
voice-port 0/0/0:15
translation-profile incoming DID
09-06-2013 10:10 AM
Hi Jack.
If you want a user to display itself with a particular number mapped on a particular pri link , you have to configure a dialpeer that matches the prefix configureg on cucm and sets the exit the exact voice port. that's why in your case a dial-peer pots with a destination-pattern .T will not be useful.
You should follow what me and Jaime suggested you on our previous posts.
Carlo
09-06-2013 10:17 AM
Dear Carlo,
I am a beginner for CVOICE, so forgive my silly question.
You'll are experts definately i will follow you, I am asking just to be clear my doubts.
I have a 4 digit extension so this mean ITSP will recive from me 4 digit, but they are expecting from me 8 digit so how can i translate.
Please reply
09-06-2013 11:17 AM
Hi Jack don't worry ;)
Regarding you calling number...
if the DID assigned from the provider is 2222XXXX on port 0/0/0 and your extension is 1000 selecting voice port 0/0/0 by configuring dial peer as suggested, the you will be displayed as 22221000 without any translation.
For incoming call your translation are correct.
you should apply it on incoming dialpeer.
eg.
incoming called number 2222....
translation-profile incomig DID
as you correctly assumed .
You are new but your are doing great!
Carlo
09-06-2013 12:10 PM
Dear Carlo,
Thanks for the reply and being patients to reply me questions
May be i am not understanding but pls correct me,
