E1 PRI - R2 config help needed!
Hi all,
Can someone please post a typical or suggested current/known working configuration of an E1 "PRI" with R2 signaling for incoming voice (DID) + outbound PSTN
I have 10 channels available from the Provider (TELMEX) in Mexico so not sure if and where I need to configure a D-channel ?
I am used to only using US based 23B+1D configurations so any help with this R2 Mexico E1 would be great
Im using a 2921 ISR with a VWIC3-2MFT-T1/E1 card and a PVDM3-32 DSP running CME 8.6
We only have a small 1 hour window tomorrow AM to test - I'm moving the E1 from a production Mitel system to my 2921 CME To test before we permanently migrate/cut over to the CME in a few days -
so this is my only chance to get the new Cisco configured and ready with a live E1 before the cut! So really helps to have a verification/sanity check of what my config should be before I start testing, as to not waste my only window of opportunity with a live circuit)
THANKS so much in advance
MJ
1 REPLY
Blue
HI
Following link shows you E1 R2 configration.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a00800ad389.shtml
or
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/246672r2.pdf
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
656
