E1 PRI with CallManger
I Have a callmananager ver 6 with Voice h323 Bateway and E1 PRI interface
When Phone from Callmanager call the outside called number doest hear anything
But with the Phone form CallManger Express ist working fine fro the same Gateway
Hall of Fame Super Gold
Re: E1 PRI with CallManger
IN my situation the ring its OK ,
The problem is ;
I can hear the other side , bu the other side cant hear me
Any firewall between the callmanager and voice gateway?
Sure ! No firewall
From the callmanger express its working fine
Have you followed the steps in the document mentioned above? Your specific case is detailed there.
The document above it was not my situation.
Any way thaks a lot for your feedback
But I had already solve the problem
Its was a routing problem , I meas the VOice Gateway couldn ping to the IP Phone
I solve this routing problem and its working fine now
Best Regards to all
109
