E1 R2 ANI request
Hi Every one, I am configuring an e1 on a 5850 that has 24- channelized E1/ PRI port,
I have 1 E1 conencted on a DMS 100 Nortel Switch where we get all teh PSTN calls,  the problems is that we need to get the Calling number (ANI) on our 5850 so that we can send this to another Voip gate way using Sip protocol, and we need the ANI for record porpose.. All the calls Terminate succesfully on the other gateway, but  we need to send the calling number ANI for record porpose..
when i do a
call active voice breif
this is what i get
Telephony call-legs: 1
SIP call-legs: 1
H323 call-legs: 0
MGCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 2
3686 : 175836120hs.1 +70 pid:1007 Answer  active
dur 00:00:03 tx:0/0 rx:104/2306
Tele 0/3:3 (875406) [0/3.23] tx:3990/0/0ms g723r63 noise:-54 acom:89  i/0:-83/-40 dBm
3686 : 175836121hs.1 +69 pid:1008 Originate 19032122704 active
dur 00:00:03 tx:104/2306 rx:0/0
IP 198.135.222.91:17018 rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g723r63
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
on the logs there si no callin gnumber ANI.
this is this si the log when i do a   debug ccsip calls
Nov  9 16:08:42.515: //875409/BF2F2504A4AB/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x669A82D8
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           :
Called Number            : 19032122704
Source IP Address (Sig  ): 200.32.250.16
Destn SIP Req Addr:Port  : 0.0.0.0:5060
Destn SIP Resp Addr:Port : 0.0.0.0:0
Destination Name         : 198.135.222.91
BZE-VOIP-GWY01#
Nov  9 16:08:42.515: //875409/BF2F2504A4AB/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g723r63
Negotiated Codec Bytes   : 24
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101
Source IP Address (Media): 200.32.250.16
Source IP Port    (Media): 19140
Destn  IP Address (Media): 198.135.222.91
Destn  IP Port    (Media): 17468
Orig Destn IP Address:Port (Media): 0.0.0.0:0
BZE-VOIP-GWY01#
BZE-VOIP-GWY01#
BZE-VOIP-GWY01#wr
Nov  9 16:08:50.155: //875409/BF2F2504A4AB/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
Calling Number           :
Agian no calling number ANI on the Sip leg of the call...
this is the config I am using on the E1, and on the dial peers..
controller E1 0/3
framing NO-CRC4
ds0-group 3 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 3
  country guatemala
  ani-digits min 0 max 40
dial-peer voice 1006 pots
description BBG Calls
destination-pattern 19032122704T
direct-inward-dial
port 0/3:3
forward-digits all
dial-peer voice 1008 voip
description BBG 871_875
voice-class codec 1
session protocol sipv2
session target ipv4:198.135.222.91
dtmf-relay rtp-nte h245-alphanumeric
the technician from the Nortel Switch say they are sending both the, ANI and DNIS for all calls, on the 5850 I can see the DNIS, but not the ANI "calling Number".
Notice: when i configured   ani-digits min 1 max 40         No calls get through
and when i change it to     ani-digits min 0 max 40    all calls go through
like if the calls are droppped because the 5850 is not getting any Ani from the Nortel switch.
Any suggestion, other configuration I can try so as to see teh ANI Calling Number, or changes i can do on the 5850 for the E1 R2 connection...??????
is highly appreciated..
thanks danny
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: E1 R2 ANI request
You want to run 'debug vpm sig' on the 3660.
For the 5350, additional debugs you can run are:
debug sigsm r2
debug sigsm sm
debug sigsm digits
debug csm voice
debug csm neat
I agree that the issue is the other side not sending ANI, though.  We can prove it if you get debugs that show the digit delivery during the call setup to see it is switching to group II, and sending the calling party number, but it may be more time effecient to get someone to scrub the Nortel config for proper ANI delivery config.
It looks like the other side isn't configured to send you ANI, which is why the call only works when the min ANI length of 0 works.
Can you get 'debug vpm sig' during an inbound call?
Also, verify that your provider is, in-fact, configured for compelled.
Steven ,
Thanks for your rapid response, and your help…
This is the IOs version we are using on our 5850, and does n’t supports the """" debug vpm sig“"”'
Is their any other debug I can use???????????? To monitor the calls and see if we are getting the ANI?????
BZE-VOIP-GWY01#sh ver
Cisco IOS Software, 5850 Software (C5850-P9-M), Version 12.3(7)T11, RELEASE SOFTWARE (fc3)
ROM: System Bootstrap, Version 12.1(5r)XV, RELEASE SOFTWARE (fc1)
ROM: 5850 Software (C5850-P9-M), Version 12.1(5)XV2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Cisco c5850 (R7K) processor (revision 0.12) with 458752K/65536K bytes of memory.
Processor board ID SAA05034541
R7000 CPU at 259MHz, Implementation 39, Rev 2.1, 256KB L2, 2048KB L3 Cache
Last reset from power-on
1 FastEthernet interface
2 Gigabit Ethernet interfaces
648 terminal lines
24 Channelized E1/PRI ports
507K bytes of NVRAM.
Steven
We have another connection to the same switch to a C3660 Router that we use for our dialup connection;
can u please give me a debug command??? so as to be able to see , when a call is setup for a dialup connection,
and if it is picking up the ANI???
This are the config we are using on the C3660
BMP-AGGR-RAS01#show ver
Cisco IOS Software, 3600 Software (C3660-TELCO-M), Version 12.3(14)T7, RELEASE SOFTWARE (fc2)
ROM: System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
BMP-AGGR-RAS01 uptime is 1 year, 15 weeks, 4 days, 4 hours, 41 minutes
System returned to ROM by error - a Software forced crash, PC 0x61168918 at 09:09:11 Belize Tue Dec 30 2008
System image file is "flash:c3660-telco-mz.123-14.T7.bin"
Config on E1
controller E1 2/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
interface Virtual-Template1
ip unnumbered FastEthernet0/0
no logging event link-status
no snmp trap link-status
peer default ip address pool BTLBLP1
ppp authentication pap chap
ppp multilink
interface Group-Async1
encapsulation ppp
async mode interactive
no fair-queue
ppp multilink
group-range 129 158
danny
The debug for that platform is 'debug cas' for in-band signaling.
Steven..
This are the logs when i do a ""debug cas"" on the c3660 router that we are unsing for our dailup connection,
BMP-AGGR-RAS01#debug cas
CAS debugging is on
BMP-AGGR-RAS01#
BMP-AGGR-RAS01#
BMP-AGGR-RAS01#
BMP-AGGR-RAS01#
BMP-AGGR-RAS01#
BMP-AGGR-RAS01#
BMP-AGGR-RAS01#
BMP-AGGR-RAS01#
*Apr 18 15:39:20.791: Message from Trunk E1 (2): debug-cas is on
*Apr 18 15:39:20.795: Message from Trunk E1 (2): debug-cas is on
*Apr 18 15:39:20.795: Message from Trunk E1 (3): debug-cas is on
*Apr 18 15:39:20.803: Message from Trunk E1 (3): debug-cas is on
BMP-AGGR-RAS01#
BMP-AGGR-RAS01#
*Apr 18 15:39:31.507: Message from Trunk E1 (2): (1/14): TX BWD_CLEAR (ABCD=1101)
*Apr 18 15:39:33.059: Message from Trunk E1 (2): (1/14): RX_IDLE (ABCD=1001)
*Apr 18 15:39:35.355: Message from Trunk E1 (2): (1/14): TX IDLE (ABCD=1001)
*Apr 18 15:39:39.387: Message from Trunk E1 (3): (0/5): RX SEIZURE (ABCD=0001)
*Apr 18 15:39:39.547: Message from Trunk E1 (3): (0/5): TX SEIZURE_ACK (ABCD=1101)
*Apr 18 15:39:40.079: Message from Trunk E1 (2): (1/29): TX BWD_CLEAR (ABCD=1101)
*Apr 18 15:39:41.871: Message from Trunk E1 (2): (1/29): RX_IDLE (ABCD=1001)
*Apr 18 15:39:44.167: Message from Trunk E1 (2): (1/29): TX IDLE (ABCD=1001)
*Apr 18 15:39:44.503: Message from Trunk E1 (3): (0/5): TX ANSWERED (ABCD=0101)
*Apr 18 15:39:52.743: Message from Trunk E1 (2): (0/4): RX SEIZURE (ABCD=0001)
*Apr 18 15:39:52.903: Message from Trunk E1 (2): (0/4): TX SEIZURE_ACK (ABCD=1101)
*Apr 18 15:39:57.927: Message from Trunk E1 (2): (0/4): TX ANSWERED (ABCD=0101)
*Apr 18 15:40:26.806: Message from Trunk E1 (2): (0/4): TX BWD_CLEAR (ABCD=1101)
*Apr 18 15:40:29.130: Message from Trunk E1 (2): (0/4): RX_IDLE (ABCD=1001)
*Apr 18 15:40:31.422: Message from Trunk E1 (2): (0/4): TX IDLE (ABCD=1001)
*Apr 18 15:43:08.501: Message from Trunk E1 (3): (0/5): TX BWD_CLEAR (ABCD=1101)
*Apr 18 15:43:09.988: Message from Trunk E1 (3): (0/5): RX_IDLE (ABCD=1001)
*Apr 18 15:43:12.284: Message from Trunk E1 (3): (0/5): TX IDLE (ABCD=1001)
BMP-AGGR-RAS01#
BMP-AGGR-RAS01#
the Switching Technician keep saying that they are sending the ANI and DNIS, and that their E1 configuratiosn is set to r2-compelled ani,  I strongly think that the problems is on the Nortel switch side that is not sending the ANI to our gateway.....
still we can't see any ANI nor DNIS, for the calls when we are are using our dialup connection,,,
Any More dubug commands that i could try???? or other suggestions, configuration i can try?????
thanks
danny
debug sigsm r2
debug sigsm sm
debug sigsm digits
debug csm voice
debug csm neat
I did a       debug csm voice   and again no calling party number..     just  called party=19032122704
Nov 12 13:31:34.421: csm_check_accept_voice_call: controller=0/0, bchan=2 calling_party= called_party=19032122704
Nov 12 13:31:34.421: CSM v(4/202) c(E1 0/0:2): CSM_PROC_IC3_WAIT_FOR_RES_RESP: (state=0x203) ev_RESOURCE_OK.
Nov 12 13:31:34.421: csm_proc_ic3_wait_for_res_resp (4/202) Switching to voice
Nov 12 13:31:34.429: csm_vtsp_call_setup_request_np (vtsp_cdb=0x637DD888, vtsp_sdb=0x66A65838)
Nov 12 13:31:34.429: csm reserve signaling channel:requested controller 3
BZE-VOIP-GWY01#
Nov 12 13:31:39.445: csm_vtsp_call_disconnect: (voice_vdev = 0x0, cdb=0x637DD888)
Nov 12 13:31:39.445: csm_vtsp_call_disconnect NULL voice_vdev from VTSP, cdb 0x637DD888
Nov 12 13:31:39.705: csm_vtsp_call_alert (vtsp_cdb=0x637DD5E8)
Nov 12 13:31:39.705:   CALL_ALERT:   type 1, sig val 1, country 0
Nov 12 13:31:39.705: csm_vtsp_call_bridged (vtsp_cdb=0x637DD5E8)
Nov 12 13:31:39.705: csm_vtsp_signaling_complete (vtsp_cdb=0x637DD5E8, vtsp_sdb=0x67289D34), oli(0)
Nov 12 13:31:39.989: csm_vtsp_call_feature (vtsp_cdb=0x637DD5E8, feature=24)
BZE-VOIP-GWY01#
Nov 12 13:31:44.753: csm_vtsp_call_disconnect: (voice_vdev = 0x66539A24, cdb=0x637DD5E8)
I will try to get someone on Nortel switch to try other configuration as to allow the ANI reach our gateway…..
Steven you really help me a lot, thanks for everything,………
E1 R2 ANI request
Dear Danny, did you get any reason for the problem as i am facing the same problem, i can't calling or called number so i can't transfer the call to call manager.
1657
