E1 R2 between 2811 and Nortel 11C receiving dialed digits
Hi, i have a problem. When i make calls from Callmanager to PBX Nortel works. But calls from PBX Nortel to Callmanager there a delay a couple seconds then i hear dial tone ,i dial the number and works.Any idea?
PBX Nortel--E1R2---GW2811--Callmanager
PBX Nortel 11C rls 81
Gw2811 IOS c2800nm-spservicesk9-mz.124-3i
Callmanager 5.1.3
Re: E1 R2 between 2811 and Nortel 11C receiving dialed digits
Sounds like you need an inbound dial peer with "direct-inward-dial" such as:
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
Hope this helps.
Brandon
Hi Brandon, but the problem still continue.
Hi ...pls need help.
The debug is attch.
Hall of Fame Super Gold
As Brandon said, this is caused by need of direct-inward-dial. may be you have another pots DP being matched before DP 1, need to check config.
Run "debug voip dialpeer" and see what dial peer is being matched.
Brandon
Dear Brandon
Now is working. I saw in the debug voip dialpeer that the PBX send a five digit. I put a num-exp and all works.
Thanks a lot!
237
