E1 R2-Digital in 2851 not receiving dialed digits
Hello
I am having an issue with an E1 R2-Digital connection between a CME and a Nortel Meridien 11C PBX. The Nortel and the CME are connected via E1 R2-Digital connection (unfortunatelly the Nortel doesn't have a PRI board available). The Cisco phones can dial any extension in the Nortel without a problem, but when the Nortel dials no dialed digits come. Oddly, when connected to another router, aa 2811, using the same IOS (12.4(15)T4) and same commands, it works. only difference between the working and no working routers I could spot is the E1 card. In the router it works is a WIC1-1MFT-E1 and the one that does not work is a WIC2-1MFT-T1/E1.
debug voip dialpeer gives me for example
//-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x481FF230,
extract of sh run
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
voice-card 0 !===> this line and the 2 below are different in the other router, just to be clear
dspfarm
dsp services dspfarm
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-12 type r2-digital dtmf dnis
voice-port 0/0/0:0
timeouts initial 3
timeouts interdigit 3
dial-peer voice 6000 voip
destination-pattern 6...
session protocol sipv2
session target ipv4:<<ip of Unity express>>
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1000 voip
translation-profile outgoing tie-line_outgoing
destination-pattern 5T
session target ipv4:<< ip of gateway router>>
dtmf-relay rtp-nte
fax rate 14400
ip qos dscp ef signaling
no vad
dial-peer voice 10 pots
destination-pattern 9T
no digit-strip
direct-inward-dial
port 0/0/0:0
dial-peer voice 100 voip
destination-pattern ...T
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 6001 voip
incoming called-number 6A0[12]....
codec g711ulaw
no vad
dial-peer voice 750 pots
destination-pattern 25..
no digit-strip
direct-inward-dial
port 0/0/0:0
1 REPLY
Hall of Fame Super Gold
Re: E1 R2-Digital in 2851 not receiving dialed digits
If you are 100% sure that with same identical IOS and configuration VWIC works but VWIC2 do not, your only option is to engage the TAC, prove your case, and wait for the results of their investigation.
330
