E1 to E1 Call Transfer
I have Cisco 2811 router with VWIC-2MFT-E1. One port is for PBX and other one is for Telco PRI line. My Telco Number is 8664900 with 100 DID. I dial this number and router answer the call. I want to transfer all incoming call from Telco line to PBX PRI line.
I do this with connection plar. Under Telco PRI voice-port i write connection-plar 8664900 and transfer all call the pots dial peer. Under pots dial peer forward 3 digit of number to PBX voice-port. But this configuration only transfer one DID to PBX. I want all incoming DID to forward PBX voice-port. For example when i call 8664900, 8664901, 8664902 numbers i should send 900, 901, 902 ... to PBX. How should resolve this problem. I am sending my configuration. Thank you...
TELCO PORT
voice-port 0/0/0:15
PBX PORT
voice-port 0/0/1:15
input gain 4
output attenuation 4
cptone TR
timeouts interdigit 2
description Connect To PBX
bearer-cap Speech
FOR CALL TRANSFER
dial-peer voice 14 pots
description *****TELCO_TO_LG_PBX*****
destination-pattern 86649..
no digit-strip
direct-inward-dial
forward-digits 3
Ufuk Guler
Silver
Re: E1 to E1 Call Transfer
You need "isdn number called enbloc XX" . Please send output of "debug isdn q931" with "term mon". Also check "show controllers e1" as you may have slips withiut the needed "network-clock-participate" and network-clock-select" commands.
Hi Guler
I already worked with a similar scenario.
The only diference was that When I received the GDN number from PSTN, it must have ring on the extension Cisco.
You have to talk with PBX staff if you need a OVERLAPPING OR ENBLOC,in my case was OVERALPPING.
The CallManger and PBX Ericsson use the access code 64T for calls to PSTN.
Below you will find the dial-peers:
controller E1 0/0/0
pri-group timeslots 1-31
description E1 ISDN PRI TELEMOVIL
controller E1 0/0/1
clock source internal
description E1 ISDN PRI PBX
interface Serial0/0/0:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
no ip address
isdn overlap-receiving T302 2000
isdn protocol-emulate network
isdn bchan-number-order descending
no cdp enable
voice-port 0/0/0:15
voice-port 0/0/1:15
dial-peer voice 1 pots
description Enable DID for PSTN Trunk
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 pots
description Enable DID for PBX Trunk
direct-inward-dial
port 0/0/1:15
dial-peer voice 3 pots
description Calls from PSTN to PBX
destination-pattern 1...
port 0/0/1:15
forward-digits all
dial-peer voice 4 voip
tone ringback alert-no-PI
description Calls to CCM
destination-pattern 2...
progress_ind setup enable 3
voice-class codec 4
session target ipv4:10.3.0.25
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 5 pots
description Outgoing Calls to Telemovil
destination-pattern 64T
progress_ind alert enable 8
direct-inward-dial
port 0/0/0:15
dial-peer voice 2507100 pots
description GDN:2507100 TO DN:2000
translation-profile incoming pstn-incoming10
incoming called-number 1000
direct-inward-dial
port 0/0/0:15
REGARDS
WALTER FLORES
Hi Walter,
Many thanks for answer. I solved my problem using another PBX PRI card. I connect Telco line to this card. And PBX answering incoming PRI calls. But as soon as possible i try your solution. Thank you...
Ufuk Guler.
When you're working to get this set up, redirect your debug isdn q931 messages to the PRI debugger from download.com - it'll make it much easier to see what's going on.
http://www.download.com/E1-PRI-Debugger-Full-for-Voip-Platforms/3000-2085_4-10831966.html?tag=lst-1&cdlPid=10832519
167
