E1 to E1
any one having experience in connecting togther two E1 between routers in a lab environment...
Re: E1 to E1
If you're doing PRI it is very simple.
Make sure that you have a T1/E1 crossover cable (not the same as a normal crossover) between the two ports.
On one side your configuration will look this this:
controller e1 0/0/0
clock source line
pri-group timeslots 1-31
network-clock-select 1 e1 0/0/0
interface serial0/0/0:15
isdn incoming-voice voice
Other side:
controller e1 0/0/0
clock source internal
isdn protocol-emulate network
hth,
nick
Community Member
Re: E1 to E1
Hello! Could someone explain why we need command "isdn protocol-emulate network/user"?
As I understand it's for defining who is clock master and clock slave on E1 line?
If is that so why we need command "clock source internal/line"?
Re: E1 to E1
There are two different layers you're working there.
clock source line refers to the synchronization of bits in the layer 1 and layer 2 level. This is a generic T1-level configuration. You would use this for many different types of T1 connections.
The 'isdn protocol-emulate network' decides which side is going to be the Q.931 network or user side switch. This enables a different type of Q.921 and Q.931 messaging between the device. This configuration is specific to PRI's.
hth,
nick
253
