E1 trunk only takes one channel
Hi I have an E1 trunk to Avaya s8400
The thing is that the first call can be completed and is working fine, once that other phone makes a second phone call we see that the second channel was taken but there is no audio.
The main configuration is:
controller E1 2/0
framing NO-CRC4
pri-group timeslots 1-31
isdn switch-type primary-net5
interface Serial2/0:15
no ip address
no logging event link-status
isdn overlap-receiving
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
isdn outgoing display-ie
dial-peer voice 10 pots
incoming called-number ....
destination-pattern 1...
no digit-strip
direct-inward-dial
port 2/0:15
forward-digits all
dial-peer voice 60 voip
destination-pattern 6...
session target ipv4:1.96.1.1
codec g729br8
ip qos dscp cs5 media
dial-peer voice 30 voip
destination-pattern 3...
session target ipv4:1.48.1.1
codec g729br8
Any idea what is going on?
I'm attaching a debug that shows that first call reaches 3700, and second call(with no audio) to 6700.
Thanks in advance!
Orlando
Gold
Re: E1 trunk only takes one channel
Orlando,
try to change the 'isdn bchan-number-order ascending' for 'isdn bchan-number-order descending'.
Sometimes this has worked for me.
Hope this helps,
Juan Luis
I tried and it didn't work.
I've even just enabled the second channel, and I get no audio.
Here is a debug of it.
BNB-LPZ-A#
Feb 20 15:05:07.345: ISDN Se2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x5901
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18382
Preferred, Channel 2
Progress Ind i = 0x8183 - Origination address is non-ISDN
Called Party Number i = 0x80, '6700'
Plan:Unknown, Type:Unknown
Locking Shift to Codeset 6
Codeset 6 IE 0x28 i = 'Prueba'
Feb 20 15:05:07.353: ISDN Se2/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xD90
Channel ID i = 0xA98382
Exclusive, Channel 2
Feb 20 15:05:08.641: ISDN Se2/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0xD901
Progress Ind i = 0x8188 - In-band info or appropriate now available
Feb 20 15:05:48.457: ISDN Se2/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x59
01
Cause i = 0x8190 - Normal call clearing
Feb 20 15:05:48.461: ISDN Se2/0:15 Q931: TX -> RELEASE pd = 8 callref = 0xD901
Feb 20 15:05:48.477: ISDN Se2/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x
5901
Feb 20 15:07:10.011: %SYS-5-CONFIG_I: Configured from console by vty2 (1.16.2.23
6)
Feb 20 15:07:15.207: ISDN Se2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x5982
Sending Complete
Standard = CCITT
Feb 20 15:07:15.215: ISDN Se2/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xD98
Feb 20 15:07:16.503: ISDN Se2/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0xD982
Feb 20 15:07:40.778: ISDN Se2/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x59
82
Feb 20 15:07:40.782: ISDN Se2/0:15 Q931: TX -> RELEASE pd = 8 callref = 0xD982
Feb 20 15:07:40.798: ISDN Se2/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x
5982
I don't get this event:
Feb 20 13:59:53.130: ISDN Se2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x4680
any more ideas?
Hall of Fame Super Gold
Do you have compand-type a-law under voice-port ?
What platform is this ? Can you send debug
Now I've configured a-law, but the problem persists.
this router is a 3725.
cisco 3725 (R7000) processor (revision 0.1) with 119808K/11264K bytes of memory.
Processor board ID JMX0642L7XA
R7000 CPU at 240Mhz, Implementation 39, Rev 3.3, 256KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
4 Serial(sync/async) network interface(s)
8 Low-speed serial(sync/async) network interface(s)
1 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
55K bytes of non-volatile configuration memory.
31296K bytes of ATA System CompactFlash (Read/Write)
I've attached a debug in a previous message.
thanks,
Orlando
I do not see the hw codecs in show version.. nor the IOS version.
perhaps show diag would tell what you have.
Also, when you have two calls, look at "show voice dsp". it is important to understand how codec are allocated.
246
