E1 Up/Down Issue
So I have an E1 in India connected to a 2911 that has been nothing but problems since we connected it.  It is going up and down quite frequently, but dealing with the carrier over there through our local contact has been quite problematic.  To give you an idea, when this was first reported to them they came out, swapped the power cable to their device and told us to reboot our gateway as that would fix the problem.  LOL!
Anyway, I've been troubleshooting as much as I can and want some hard evidence that it's them.  Our controller is showing tons of errors:
E1 0/1/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK1
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Data in current interval (607 seconds elapsed):
     0 Line Code Violations, 41271 Path Code Violations
     9 Slip Secs, 4 Fr Loss Secs, 0 Line Err Secs, 1 Degraded Mins
     94 Errored Secs, 28 Bursty Err Secs, 18 Severely Err Secs, 4 Unavail Secs
  Total Data (last 11 15 minute intervals):
     0 Line Code Violations, 1706511 Path Code Violations,
     81 Slip Secs, 87 Fr Loss Secs, 0 Line Err Secs, 32 Degraded Mins,
     3707 Errored Secs, 489 Bursty Err Secs, 275 Severely Err Secs, 48 Unavail Secs
I turned on q921 debugging and am getting this constantly in the logs:
097200: Oct 29 00:07:38.803 IST: ISDN Se0/1/0:15 Q921: L2_EstablishDataLink: sending SABME
097201: Oct 29 00:07:38.803 IST: ISDN Se0/1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
097202: Oct 29 00:07:38.811 IST: ISDN Se0/1/0:15 Q921: User RX <- UAf sapi=0 tei=0
097203: Oct 29 00:07:48.807 IST: ISDN Se0/1/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=0
097204: Oct 29 00:07:48.807 IST: ISDN Se0/1/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=0
097205: Oct 29 00:07:58.807 IST: ISDN Se0/1/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=0
097206: Oct 29 00:07:58.815 IST: ISDN Se0/1/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=0
097207: Oct 29 00:08:08.811 IST: ISDN Se0/1/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=0
097208: Oct 29 00:08:08.811 IST: ISDN Se0/1/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=0
097209: Oct 29 00:08:09.795 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to down (10 SES)
097210: Oct 29 00:08:09.795 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
097211: Oct 29 00:08:10.795 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to up
I'm actually not certain what that is indicating, but am pretty sure it's saying something is wrong on their side.  Either that or they gave us the wrong information about framing and linecode and that is what is causing all of the issues.
Any other suggestions on what I can do to troubleshoot or is this clearly a case where the carrier will have to fix something?
pls post your running config
Hi.With this statistic, two
Hi.
With this statistic, two things I would check.
First Cabling quality between 2911 and TSP Device.
Second, but most probable, an Issue with TSP equipment.
Let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
VIP Purple
Hi, Since u are getting lot
Since u are getting lot of CRC and slips, did u get the media checked.
You can try giving physical loop from your side and ask Telco to check.
can u also share show inventory/show diag from 2911 and show version?
regds,
aman
Here is the inventory and
Here is the inventory and version.
NAME: "CISCO2911/K9 chassis", DESCR: "CISCO2911/K9 chassis"
PID: CISCO2911/K9      , VID: V07 , SN: FGL17491136
NAME: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 1", DESCR: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-1MFT-T1/E1  , VID: V01 , SN: FOC17478R9G
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN: FOC174596SY
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V05 , SN: DCA1744R1T0
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FGL17491136
3 Gigabit Ethernet interfaces
31 Serial interfaces
1 terminal line
1 Channelized E1/PRI port
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FGL17491136
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
VIP Purple
Hi,You can refer the
You can refer the link
https://supportforums.cisco.com/discussion/11879381/t1-pri-errors
I have captured the snapshot from same link .Try this if E1 media is error free.
Just went through this same scenario.  Did the whole dance with the carrier (they tested end to end, ran clean of course, threatened them etc. ). Tried on two different 3925e's with a VWIC3-4MFT in both.  Then a VWIC3-2MFT with the same result.  Tried a VWIC2-1MFT, and it came up perfectly.
Got TAC on the phone, guy found the bug (CSCua50697), said it was fixed in the verison i was running (15.2.M4 or something), we upgraded to 15.3.M3 with the same results.
Long story short, there IS a work around.  Put this command under your controller: hwic_t1e1 equalize
It's a hidden command they put in there just for this problem.
regds,
aman
This gateway is on 15.0(1r
This gateway is on 15.0(1r)M16 so it appears the hidden command isn't doable.
VIP Purple
I suggest taking physical
I suggest taking physical loop [physically shot the pairs ] and ask Airtel to check for the loop.this should be error free.
regds,
aman
Here is the config with parts
Here is the config with parts left out that aren't relevant.
Building configuration...
Current configuration : 8017 bytes
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
boot-start-marker
boot-end-marker
card type e1 0 1
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 10000000
no logging console
no logging monitor
no aaa new-model
clock timezone IST 5 30
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
 import all
 network 10.10.10.0 255.255.255.248
 default-router 10.10.10.1
 lease 0 2
isdn switch-type primary-net5
voice-card 0
voice service voip
 ip address trusted list
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
 codec preference 1 g729r8 bytes 40
 codec preference 2 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 3
voice iec syslog
license udi pid CISCO2911/K9 sn FGL17491136
hw-module pvdm 0/0
redundancy
controller E1 0/1/0
 pri-group timeslots 1-31
 description ***Airtel E1***
ip ssh time-out 60
ip ssh authentication-retries 2
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/1/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 isdn map address . plan unknown type unknown
 isdn supp-service name calling
 no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 0/1/0:15
Hi Shanen,If call are been
Hi Shanen,
If call are been established fine at least for a short time that means is not a line code or framing mismatch. Look like a layer 1 problem (cable between CME and Provider). Maybe the cable is damaged somehow.
Please remember to rate useful posts clicking on the stars below. Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo. ___________________________________________ LinkedIn Profile: do.linkedin.com/in/leosalcie
Calls can be established as I
Calls can be established as I do see active inbound/outbound calls on the gateway.  However, they sometimes experience busy's when dialing out or sometimes get reports of busy's when someone tries to call their local numbers.  I asked my local contact earlier this morning to replace the ethernet cable between the provider's device and our gateway.  I will see if that makes any difference.
339
