E1
hi
I have CISCO 7.1  integrated with nortel 81c with 4 PRI-QSIG link, I need to know if its enough for 500 users, if there is any tools in cisco to calculate that,
please provide.
Re: E1
This is calculated using the Erlang formula. Free Erlang calculators are available in the internet. Use Erlang B for the calculation of necessary B-Channels (which is what you need). Callcenter calculators are using the Erlang-C formula. Here is only one of the many examples:
Erlang B: http://www.erlang.com/calculator/erlb/
Erlang C: http://www.kooltoolz.com/ccm.htm?gclid=COOX0Jq586ICFUfX5woddySqhQ
Best
  Patrick
Re: E1
Hi Patrick,
I think he is asking about normal users not Contact Center.
Erlang calculation for Call Centers.
Erlang B to calculate IVR and trunk ports ( as you know in IPCC you are expection calls more than agents)
Erlang C to calculate the Agents.
Hall of Fame Super Gold
Re: E1
Erlang "calculations" are useless in most cases.
Some users do a lot of calle and some do never calls.
The only working way is to observe real usage of an exisiting trunk.
E1
In addition to the earlier provided free Erlang calculators one can also use this online erlangc calculator at
http://www.agenses.com/489/free_erlangc_calculator/
Feel free to use it
There is also an Erlang C
There is also an Erlang C Calculator in Excel format which could help with your calculations
Erlang C Calculator
This also contains shrinkage calculations so will be more accurate.
315
