Community Member
Echo in 7936
I have CP-7936 (Application Load ID: cmterm_7936.3-3-13-0, Software Version: 3.3(13.00.0008))
installed with ccm 4.1.3(sr5b)
there is echo in the line, when i replace 7936 with any speaker phone it works without echo.
we have PRI(e1) to ccm(mgcp)
1 REPLY
Silver
Re: Echo in 7936
You may try enabling echo suppressor to reduce the echo during the first two to three seconds of a call, while the echo canceler converges.
Configuration
gateway(config-voiceport)#echo-cancel ?
coverage Echo Cancel Coverage
enable Echo Cancel Enable
suppressor echo suppressor
198
