Echo issues
cris_jimenez
Level 2
Level 2
we have echo issues with incoming and outgoing calls.
we are running CCM 5 and we have a 2851 GW
could you please point me to some troubleshooting steps
thank you
paolo bevilacqua
Which kind of lines do you have and which exact IOS do you hae ?
8 Replies 8
paolo bevilacqua
IOS Version 12.4(3g), RELEASE SOFTWARE (fc2)
I have a PRI
jcraven
It doesn't seem to make sense at first, but echo=DSPWare issue. And the DSPWare issue is resolved by the right IOS. as others are stating, check out that link to the other thread. and, if someone wnated to rate my original post that refers to the specific bug ID and my experience, it would not hurt my feelings. he he.
cheers,
Jerry
I did rate it Jerry. Thank you for sharing your findings!
flopez
there are also QOS settings you can change on the router and switches that might help. But you will have to contact Cisco TAC and talk to the QOS team. If you are using Auto-QOS this is likely to happen.
I just upgraded the IOS of my GW, I will monitor for the next few days and hopefully that will fix my issue if not I will open a TAC case to troubleshoot QoS
using ecan modules?
