Edit IP address on 7911
When i navigate to network settings->ip address there's no edit button displayed. When i press " * * # " The "EDIT" button appears, but it's grayed (disabled). How to enable it? Thank you.
Hall of Fame Super Gold
Re: Edit IP address on 7911
Set DHCP off in the same menu. You should then be able to configure IP address.
Please rate post if it helps!
Sorry, found the solution myself. You should disable dhcp from the same menu before the edit button becomes enabled.
313
