ELM 9.1 Produst In
I am running standalone ELM server. The IP if the CUCM got changed and now I get The Product Instance at the hostname/IP address has already been configured on this Enterprise License Manager. When I try to add the new server.
Nothing shows up shows up in Product Instances,
Anyone had this issue and a fix ????
It is running 9.1 on a UCS
1 ACCEPTED SOLUTION
Hi,Please check the following
Please check the following post, it should answer your query
https://supportforums.cisco.com/discussion/11716476/problem-create-new-ip-and-host-name-elm
Manish
Manish
Manish thanks for quick reply
Manish thanks for quick reply. I seen that post but when I tried it failed so since I have time I would just rebuild ELM. IT will take control of an existing ELM..
IT was likely fault but I am sure you were correct
77
